PIcs of my 408 F1R, Becool setup
#61
Video to come... need my final tune done. P1SC with Becool.... you will have to slightly mod the bottom radiator crossmember... in fact there is an install guide I believe on the Becool site that trys to explain what minor mods(bending) need to be done. I had to mod mine to the degree I did to fit the 4 in 90 on th inlet side. as fra as the hood bracket... you have to cut off the legs that come down to a v and bolt to the bottom radiator cross member bracket. I then took some flat stock .. bent them to a different angle and rebloted it to the bottom of the radiator crossmember.
#63
The exact size eludes me right this moment. I do remember being told that I was pullied for 20PSI... thus enabling me to get to my desired boost level of 15 psi and maintain at the "Desired tune RPM". I believe that is 6000. I am not using SDCE, I'm using a steel j bracket, 8-rib setup.
#71
Great contribution to the FI forum. This really helps out! What did you make your elbow out of, mild steel? How well does it clamp to the head unit?
