need a good fuel pump controller
Old Jun 22, 2007 | 11:56 AM
MIGHTYMOUSE's Avatar
exxactly
i would rather not completely redo the pump set up and supply configuration to save the guy cash.. if i had a good controller thats all i would need and i could sell this one he had.
3 inline walbros would only set me back maybe 400 bux start to finish of the change over though.. and i could kick the second two on by the dfi box... hmm
Old Jun 22, 2007 | 12:22 PM
LSInnovations's Avatar
What about a single Magnafuel running all the time for $450? no controller needed.
Old Jun 22, 2007 | 01:52 PM
SilverGhost's Avatar
Motorboater
i'm lazy and haven't wired my hobbs switch so i just have two external walbros runnign full time off my sumped 98 tank.. one of the best things i've done since putting a blower on the car, the twin in tanks i had at first sucked my ***.
Old Jun 22, 2007 | 02:39 PM
NA$TY-TA's Avatar
I went to two pumps because the Weldon 2025 I had was louder than my exhaust. I had a Weldon dial-a-flow controller but I was turned off on using it after a few folks said they had problems with them.
I dont understand ya there John...... it worked..... it was louder then then the exhaust but on a car you dont D/D or drive more then 10 times a YR....
When mine is back togeather we think ill run out of pump with the Proseries pump...... Weldon 2035 or so is next prob....... ill have to wait and see....
David any luck with DFI turning on the 2nd pump??
Old Jun 22, 2007 | 02:50 PM
stevieturbo's Avatar
I used the Aero controller with my A1000, and then with my dual Bosch setup for a while...
With both setups, I had problems with the crappy push on terminals for the pump, melting.
It would appear they werent making sufficiently good contact, and overheated/arced, and could have caused a fire.
Anyone else have similar problems ?
Im just running a plain dual Bosch in parallel, with both pumps running at all times. Simple, and it works for me. They make a little noise, installed in trunk under the tank, but once the engine is running, you cant hear them.
if Bosch pumps are good enough for OE fitment, reliability is not a concern. Ive been running them like that for over 6000 miles now, with a magnafuel regulator.
I also added a small oil ( fuel ) cooler on the return back to the tank, although its mounting location isnt ideal underneath the car.
