mustang d1 headunit
Old Jun 21, 2007 | 07:30 PM
00formLs1's Avatar
Default mustang d1 headunit
my buddy is selling his procharger d1 kit and i was wondering if it was possible to get it to work on my formula. i tried a search but didn't find much. i did see something about it spining a different way.
its off a 2003 Gt. i would probly only use the head unit and intercooler. if it was possible.
Old Jun 21, 2007 | 08:55 PM
Tudds's Avatar
It needs to be reverse rotation
Old Jun 21, 2007 | 09:19 PM
eb02z06's Avatar
If it's off a mod motor it will work-you may need to reclock the oil slinger though.
Old Jun 22, 2007 | 03:03 AM
andereck's Avatar
A 4.6 blower up to 2004 will work on an F body, you'll just need to rotate the volute, the slinger is in the right spot.
Old Jun 22, 2007 | 07:49 PM
00formLs1's Avatar
By rotating the volute do u mean moving the head unit cover so its in the right direction?
Old Jun 22, 2007 | 08:01 PM
kp's Avatar
kp
The volute is the outer cover with the discharge, just loosen the allen bolts and move it where you want the outlet to point. There are no gaskets or seals, it can go in any position, you will have to move some of the bolts around naturally.
