Heads lifting under boost: avoid?
Old Jun 26, 2007 | 08:49 PM
Frost's Avatar
Originally Posted by VENGEANCE
Ill definitely be using copper gaskets and probably just go ahead and o ring the heads, but why a thicker deck?
I was probably going to go with some ported L92 or dart heads to save a bit of cash...
thicker deck allows for more clamping force and a more uniform sealing surface
Old Jun 26, 2007 | 09:31 PM
LASTLS1's Avatar
6 Second Club Moderator
When your lifting heads I don't think it matters if your using copper and oring. I wouldn't do it again, when your lifting heads your just screwed!
Old Jun 26, 2007 | 11:31 PM
VENGEANCE's Avatar
You wouldnt do what again?
Old Jul 17, 2007 | 08:42 PM
Firehawk853's Avatar
I'm running 16psi on aftermarket castings, 6L iron, and standard ARP fasteners.
I think I lifted the heads on both sides, it blew around the gasket at the bottom near the spark plug, but not at the top or between cylinders. I tried using the SCE ringless copper gaskets. I'm not sure if it was the gasket or timing. I know it wasn't fuel.
How much timing are you at with pump gas? I'm at 19degrees up top.
Generally speaking decreasing the timing will be safter but will run hotter correct?
Old Jul 22, 2007 | 02:15 AM
Tom@SpeedInc's Avatar
we've had better luck with MLS 6.0 gaskets or Cometic, paid $350 for Titan ICS gaskets only to have them blow first dyno pull, installation instructions followed to a T. Swapped them with a set of 6.0 MLS, no problem since.
Old Jul 22, 2007 | 05:21 PM
Yeap thats what I'm doing, stock GM gaskets I'll let you know the outcome.
