Whats the highest hp you've seen on stock cubes and 93 octane?
Old 07-02-2007 | 11:16 PM
deviate42's Avatar
kissmysso1
is the guys name
If you guys have seen that 03 cobra vs the turbo ss video...his car is ******* insane
*Pump Gas*
740rwhp
347ci
TTi race kit with GT80
His car got me hooked into turbo LS1's......
Old 07-03-2007 | 01:05 AM
SSilverSSurfer's Avatar
Originally Posted by Superman09
soooo what happened to the stock cubes part of this, haha. I wish my car came stock with 408 cubes.... Check out Tiago, he made some big bills on his 346.... in the 900's i believe
yes he did stock cubes forged with twins now hes moving on to bigger and better things
Old 07-03-2007 | 07:13 AM
rufretic's Avatar
My car is still the stock 346 and making 682 with a safe tune. I run 100 from citco to be safe but could probly get away with 93. I'm not running meth. I don't know how long it will last but if feels real strong right now.
Old 07-03-2007 | 07:27 AM
bluecamaroz28's Avatar
Originally Posted by ninetres
364 is a stock cube motor size. GTOs? Vettes? Escalades? Hummers? Trucks?
6.0L iron & LS2, sorry ur right..
Old 07-03-2007 | 07:32 AM
stock pistons are good for around 550RWHP, so, I think ur pushing the limits with 682RWHP but good number from stock 346. Any 1/4 ET and MPH.
Old 07-03-2007 | 07:38 AM
rufretic's Avatar
Yeah, I'm deffinetly pushing the limits. The only times I have right now are in sig for the 1/8 with a shitty 1.7 60', I was running out of gear so I had to let out after the 1/8. I had to slowly go to wot because I couldn't hook. I changed gears and am going back to the track on the 7th. It should be good for low 10s.
Old 07-03-2007 | 08:42 AM
ls1290's Avatar
Dumb Ass Vette Moderator
Originally Posted by vaticano
i'm interested
Shot me a PM for more details.
Keith
Old 07-03-2007 | 09:38 AM
Originally Posted by deviate42
kissmysso1
is the guys name
*Pump Gas*
740rwhp
347ci
Do u have the link for the video.
Old 07-03-2007 | 10:44 AM
eb02z06's Avatar
Last year I made 645/545 on pump and meth 346, this year I made 920/820 so far with pump and dual nozzle meth with 1 can of torco accelerator for every 5 gallons of fuel. So far the tune is very safe and the knock tables are completely stock-compression is 10.1-or slightly more
Old 07-03-2007 | 01:08 PM
At what boost is the 920/820. 10.1 CR, what cam and heads..amazing from 347.
Old 07-03-2007 | 01:19 PM
eb02z06's Avatar
Cam is very similar to what Bob at EPP sells 232 range. Heads are just $700 patriot 243 basic CNC, 227 runner-stock valves. No work done in chambers-they are stock. Boost-I'll have a better idea when my F1R comes back but it was burying the 20 psi boost guage-i have a 30 psi guage now.
Old 07-03-2007 | 01:31 PM
  #32
NicD's Avatar
7 Second Club
346ci forged low compression / PTE-76GTS - 650 rwhp/650 rwtq on 10 psi / 91 oct as that's all we get and not willing to push it any further on our shitty gas. I would probably take it up another 2 psi with 93 oct and it's ~700 rwhp/rwtq at that level.
Old 07-03-2007 | 01:49 PM
  #33
Jimmy P's Avatar
Are you pushing any water with this setup?
Old 07-03-2007 | 01:53 PM
  #34
eb02z06's Avatar
Nope-hey bro-got that D1 on there now-thanks. i'm getting about 15-16 psi with it. Changing pullies tonight and I'll dyno it with the D1 and then shooting for the track this weekend.
Old 07-03-2007 | 02:02 PM
  #35
jason99frc's Avatar
Before I sold my 99FRC it was:
Stock block, crank & heads
callies rods, diamond pistons @ 9.9:1, LS6 intake, ported stock TB, D1SC on 93 octane NO METH.
Typical corrected dyno runs were in the 670 range @ 10 psi
One cold morning (45 deg. cold in FL) the boost crept to about 13 psi and we saw 708 corrected RWHP
RE-READ ABOVE STOCK 99 LS1 HEADS WITH ONLY A SPRING CHANGE
I thought this was decent.
Old 07-03-2007 | 02:13 PM
  #36
Speed's Avatar
Bone stock engine except ls6 valve springs with 100k miles. Put down a best of 548/569 to the tires through an M6 but with a twin disc clutch and a 9in. Very conservative tune.
Old 07-03-2007 | 03:28 PM
  #37
alwaysinboost's Avatar
my forged 346 on straight 93 put down 720's @ the wheels on 14.89 psi. Car traps between 130-135.
I just added a dual nozzle meth kit so I'm looking for a little more power once I get the bugs worked out.
Old 07-03-2007 | 04:04 PM
  #38
Grr's Avatar
Grr
im trapping 125+ mph every run with my setup, stock everything 6.0L LQ4, 9.4:1 with 224 cam. S75 turbo, through the exhaust. thats through a 4l80 and stock 14" pickup converter. My HP tuners logs show 625 crank hp and average of 545 crank tq. 13psi, 10 degrees advance, non intercooled on 91 octane
Gary
Old 07-04-2007 | 08:34 AM
  #39
nitrorocket's Avatar
I am over 800 RWHP, stock cubes, NO meth, and factory heads and intake. 93 Octane.
Old 07-04-2007 | 09:08 AM
  #40
MIGHTYMOUSE's Avatar
i made two passes over 140mph with just pump no meth and melted 4 pistons, i felt so good about my decision after that.
Quick Reply: Whats the highest hp you've seen on stock cubes and 93 octane?
