help please, still have oil in my intake
I thought I had a good pcv setup but appearently not. Ive got about 5000 mi. on my new motor and I decided to take a look inside my intake and ive got oil alll over the damn place. Im running rubber hoses from both valve covers then they tee together into my catch can from there the outlet of the catch can goes into a one way check valve and then into the side of the intake. im not using the line on the blower hat at all, and Ive got a breather on the pass. valve cover witch is misting a little oil under boost. my can is a mike norris motorsports catch can. I know this issue has been beat to death and i have read hundreds of replys but I would really appreciate the help
Originally Posted by lmt0705
i believe its wire mesh inside, what do you think about what slowhawk said about eliminating the line going to the intake and putting a breather on it?
if you're going to run a breather there is no need for a catch can at all.. just cap off all exits and stick a breather on the oil fill.
