Turbo Guy's! I Need Your Help!!!!!!!
When you push water you will always push water till you change the gaskets.( I found this on a few cars)
For 14lbs I would say there was too much timing or lack of fuel which detinated the motor and lifted a head. No biggie.Replace the gaskets and lower the timing/check A/F.I can't see twins on a 370ci being a problem with only 14lbs.
