ST80 vs 76GTS some tad bit of info....more will be coming
Old 01-21-2008, 01:55 PM
B18CYA's Avatar
up from the dead! any more info on these or any comparisons to the st80
Old 01-21-2008, 02:04 PM
LS1TECH Sponsor
DrTurbo's Avatar
That comparison is about as good as you can get. The only advancement to this would be the ST80R which has the race cover and would make more power, then the next level would be the SX80 and SX80R.
Old 01-21-2008, 02:22 PM
camaroandreas's Avatar
Sounds like very much backpressure, what type of turbine A/R on the ST80?
Old 01-21-2008, 02:23 PM
LS1TECH Sponsor
DrTurbo's Avatar
We can build them from .80A/R to 1.52A/R.
Old 01-21-2008, 02:26 PM
But what was it on this test?
Old 01-21-2008, 02:40 PM
MECHAM's Avatar
read the 4th line in the post...
Old 01-21-2008, 02:49 PM
LS1TECH Sponsor
DrTurbo's Avatar
Post # 20 answered it....
https://ls1tech.com/forums/showpost....7&postcount=20
Old 01-21-2008, 02:50 PM
Sorry
Old 01-21-2008, 04:07 PM
Frost's Avatar
So what is the exhaust exit difference? I have a 76GTS, what would I need to do to my downpipe to get the 80 to bolt up?
Old 01-21-2008, 04:52 PM
BoostnTBSS's Avatar
At what RPM was 20psi reached? what kind of dyno was this on? must./dynojet ... ect
Old 01-23-2008, 03:52 PM
What sixe is the turbin in a ST80?
Old 01-23-2008, 04:25 PM
  #32
LS1TECH Sponsor
DrTurbo's Avatar
It uses a 4" downpipe vs 3" from the 76GTS.
Old 01-23-2008, 04:26 PM
  #33
LS1TECH Sponsor
DrTurbo's Avatar
This was on a dynojet I believe.....they both reached boost in the mid-low 3K range.
  #34
LS1TECH Sponsor
DrTurbo's Avatar
We use an 84mm turbine vs GTS is 82mm.
Old 01-23-2008, 04:33 PM
  #35
Ok, i was worried about the backpressure, but it will be alot less with my 96mm and 1.32 A/R.
Thanks for sharing the info.
Old 01-24-2008, 08:24 AM
  #36
70Stang's Avatar
The 76GTS was on what backside? same 1.10 ?
Old 01-24-2008, 08:37 AM
  #37
ABeasst's Avatar
I think the biggest you can get is .96
Old 01-24-2008, 10:43 AM
  #38
LS1TECH Sponsor
DrTurbo's Avatar
Correct the 76GTS was on the biggest possible which is .96A/R.
Old 01-24-2008, 11:54 AM
  #39
70Stang's Avatar
Ok..just checking.
Still, very nice power from the BW unit - spool was similar even with the bigger backside, cool.
Old 01-24-2008, 11:57 AM
  #40
LS1TECH Sponsor
DrTurbo's Avatar
Ok..just checking.
The BW though uses a divided housing so A/R's on the divided aren't accurate. A/R is based on total area over the radius to the center. Problem is they don't take into account the effect of having the divide into the area. So typicall a 1.10A/R divided is around the same as a ~.99A/R undivded housing.
Quick Reply: ST80 vs 76GTS some tad bit of info....more will be coming
