Procharger Boost Problem!
Remove the bypass valve and stop up the hose. The bypass valve is like a throttle plate and isn't designed to seal tight, or it might stick in the bore. The leakage around the blade is minimal to a flowing system and won't affect power if the diaphragm works properly.
Second don't get crazy with the air pressure. 15 psi is plenty. You could damage your intercooler(s) with 60 psi.
The area of the diaphragm is greater than the valve so boost pressure holds it closed. The spring is just there to bias the valve closed. You could run the car without the spring at all.
If you start removing components and plugging VAC lines and stuff you completly defeat the purpose of doing the test in the first place. Leave everything attached and make sure its VERY quite so you can listen for air excaping from everywhere.
That being said, DOES ANYONE HAVE A METAL PROCHARGER PLENUM THEY ARE LOOKING TO GET RID OF?!!
what I've done in the past, depending on how **** you are about looks and what kind of time frame you're working with, is dab some JB weld on the pin holes. I've tested that stuff upto 30psi with no problems.
Thanks again for the help guys!
Blake
15psi is 15psi as far as I know...
the CFM a compressor puts out doesn't matter because you aren't trying to see how much air the engine can move. All that matters when doing a boost leak test is the pressure your setup can hold w/o leaking.
the "amount" of air flowing thru the engine is a function of many different things but in a nut shell the more efficent the engine the greater the CFM the engine will move and with less pressure behind it.
Small leaks may keep a compressor from maintaining a test pressure in the system when its sitting there static but that doesn't mean you've lost any significant airflow wnen the engine is running.
Testing the system statically may help find a problem that may have been missed otherwise, but in the grand scheme of things small leaks aren't relevant.
While a shop compressor may only be able to maintain say 12 psi on a tested system its quite reaonable that when the engine is running it may be good to well over 20 psi.
Street bypass valves and volutes for instance don't "seal" per se, but the airflow lost doesn't affect performance due to the overall mass of air going through the system.
Still looking for a Plenum BTW
Blake
I second you on that fact those tiny leaks In my eyes are not going to creat that much of a boost loose...
Did you install this cam before or just now that you have a boost loose? Some cams if not designed just right can also cause boost to leak off through the exhaust... What is EPP's cam specs?
