Procharger Boost Problem!
If you don't think its the leaks he discovered then what do you suspect it is?
Having run all kinds of FI setups on many a different motor I've found that leaks in the charge piping/manifold are the cause of many headaches and usually the first place I look when diagnosing a problem. Even more so the case in a SC setup where the amount of boost you run is fixed/linear. unlike on a turbo car where the pressure lose can be overcome or hidden by unintentianly pushing the turbo harder.
Still looking for a Plenum BTW
Blake
http://www.exoticperformanceplus.com....html?item=973
http://www.exoticperformanceplus.com....html?item=972
Bob
Did you install this cam before or just now that you have a boost loose? Some cams if not designed just right can also cause boost to leak off through the exhaust... What is EPP's cam specs?
Here is our cam. We installed it in an '06 GTO last week along with an ATI ProCharger D-1SC and Kooks headers, and had it at the Super Chevy Show in Indy at the ATI booth area. We made 8 psi without going to a small pulley. Bob
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
