Lpe Tt Help
Old Jul 12, 2007 | 03:20 AM
sultan(ZR-1)KSA's Avatar
Default Lpe Tt Help
Hi there you all
i own a 2002 Corvette Lingenfelter TT stage 2 corvette with a built 347CI
and i am intrested to upgrade the turbos in the quist for more power.
can some one recomend any turbos that would fit in the same location and also fit with out any cuting of the frame or modefecation
thanks and best regards
Old Jul 12, 2007 | 04:53 AM
Inspector12's Avatar
TT-TECH Veteran
Call them and ask them, but from what I know they use a manifold that is real simular to the Incon manifold and I believe the turbos are the T28 flanges with that said I believe that you can upgrade your current turbos to GT3071R"s. Cablebandit had his done here ia s quote from one of his posts "Blouch turbo...791.50 each for the -11 or -12 cartridges including machining our housings" Hope it helps Good luck!
Old Jul 12, 2007 | 07:15 AM
cablebandit's Avatar
exactly...i do believe it is the same turbo setup as the LPE TT. The -12s will fit in your housings once they are bored out some and are not outwardly bigger so they will fit exactly like they did in your car
