Post up if you have a 3bar SD EFI/HPT tuned stock pcm FI car.
Old 12-21-2006, 07:14 PM
Coal Mining Director
onfire's Avatar
Default Post up if you have a 3bar SD EFI/HPT tuned stock pcm FI car.
I see lots of posts about 2 bar FI cars. Very few 3bar. I'm changing from a 2 bar to a 3 bar. How's the drivability? Did you use the Delphi 3bar map #12223861? That's the best low kPa resolution 3bar I could find. If this rain ever quits, I'll get to retune the 3bar.
Old 12-21-2006, 07:29 PM
Josh@KY-Turbo's Avatar
I am gonna follow along. I am gonna go straight to a 3 Bar setup with my car and the EFI Live and RoadRunner setup.
Old 12-21-2006, 07:45 PM
02SSLE's Avatar
subcribing
Old 12-21-2006, 07:49 PM
black98ws6ta's Avatar
My car drives fine with it but it is also loose auto. I wonder how the driveability would change with a 6 speed.
Old 12-21-2006, 08:53 PM
qqwqeqwrqwqtq's Avatar
I have a 3 bar stock PCM FI car. (and have tuned many others). Driveability is absolutely beautiful, much better than MAF.
Not sure of the map sensor part # but we get them from FAST.
Old 12-21-2006, 08:58 PM
Got Me SOM's Avatar
what is the advantage of running 2 bar vs 3 bar?
this is speed density right
Old 12-21-2006, 09:14 PM
ABeasst's Avatar
more boost
Old 12-21-2006, 09:23 PM
smokinHawk's Avatar
working on my hpt 3 bar set up with lowz 96lb injectors (harlan conveter)
still need to flash it and start on it as ive been lazy with it the past few months.
hopefully ill get it going soon during Christmas break
Old 12-21-2006, 09:52 PM
onfire's Avatar
The 3bar map I bought from Speed Inc (FAST brand) is made by Delphi. Best low resolution 3 bar I could find. Specs are here:
http://www.powerandsignal.com/docs/P...s/12223861.pdf
My 2bar SD tune drives much better than the maf tune....much more control over WOT af ratio too as compared to RPM vs PE tuning. The open loop tuned in so well with part throttle transitions, I'll probably leave the O2's turned off, remove them and run some leaded 112 at the track.
Hopefully, the 3bar will tune in as well as the 2bar.
Delphi also makes a 3 bar map sensor that plugs in like the factory 1bar....but the low end resolution isn't as good as the one above.
Old 12-22-2006, 10:56 AM
onfire's Avatar
Only two members so far running 3bar....
It's still raining here...I'm going to set the scalar and install it tomorrow even if I have to drive it on jack stands....idle and decel are the lowest ends of kPa resolution anyway. I idle at 35kPa and decel down to 20kPa.
Old 12-22-2006, 10:58 AM
ABeasst's Avatar
I have 3bar on my car but the turbo is being repaired so havent had much seat time.
Old 12-22-2006, 11:31 AM
kp
kp's Avatar
That 3 bar sensor is the one everyone has been using forever. Its the old TTA 3bar sensor, FAST, MSD and several others sell it but its the same sensor, I have one on my car too
Old 12-22-2006, 11:44 AM
2000 Tran Zam's Avatar
Drivability is great on my car as long as nothing is breaking. I didnt tune the car, but im running the 3 bar setup on stock pcm with rc engineering 75# inj's.
For the most part everything is real smooth and enjoyable, long as the neighbors dont come out screaming at me for my open downpipe, lol.
Old 12-22-2006, 12:57 PM
Frost's Avatar
ONFIRE-
How far are you from Richmond
I'm about to dive into 3-bar, most likely this coming week...
Old 12-22-2006, 01:07 PM
onfire's Avatar
Originally Posted by Frost
ONFIRE-
6hours
The SD part is easy in EFI Live. I stumbled at first by using a "starter tune" that was wacked. If you go through their tutorial step by step it's a walk in the park. It just takes more time than RPM vs PE since you have to populate a larger VE table....but the extra control is nice.
Post up or pm any questions that you have. My 2bar tune took some time driving the car to get the VE table spot on, but it's worth it. Part throttle is much nicer than the maf tune.
Old 12-22-2006, 01:18 PM
Frost's Avatar
I am using HPT.. I'd like to be able to go open loop too, my 02s do some funky **** and I just wiped a set out with leaded 116 befoer the dyno....
6 hours from Richmond and yer still in VA??!? heh heh I didn't know that there was such a place save for that south-west "piece" of the state that sticks out...
Old 12-22-2006, 01:23 PM
onfire's Avatar
You'll be fine with HPT.
Just look for the Bristol NASCAR track and you'll see our spot in the world.
Old 12-23-2006, 09:06 AM
2001-WS6's Avatar
I've been working on my HPT 3-bar tune this fall. The driveability had been good which is a nice perk, but that's not why we go to 3-bar.
Rick
Old 12-23-2006, 10:13 AM
cablebandit's Avatar
Tom i think i will do 3bar as well when i put my kit back on or do something different
Old 12-23-2006, 10:34 AM
onfire's Avatar
I was a major skeptic at first. RPM vs PE worked over 700rwhp. You'll really like SD. It takes some time to tune/run/log/tune/repeat....but it is more accurate as the boost moves. Plus removing the maf as a restriction and removing the O2's for race gas is a plus.
I'm tuning in segments to build a VE table that will work for all boost levels. Starting on gate spring only (10psi) and moving up 2 psi at a time on EB2. Getting the first 10 psi and part throttle tune was 95% of the work....start rich and lean er down.....and don't get arrested running WFO on the street.
Quick Reply: Post up if you have a 3bar SD EFI/HPT tuned stock pcm FI car.
