Building some v6 turbo headers
Old Jul 12, 2007 | 10:41 AM
Speed's Avatar
Default Building some v6 turbo headers
Well I picked up a little v6 car for an LSx build but decided to put together a set of headers for a gentleman that wanted the engine. He is building his own kit but wanted a little help making the ball of snakes fit on the sides of the engine so I volunteered. Got the drivers side done and will hopefully finish up the passenger side in the next couple of days. I'll tell ya the V6 guys have it right when it comes to room under the hood!
The drivers side header pictured below installs fairly easily but it does require moving the dipstick tube out of the way or removing it and snaking it between the primaries. Once installed, there is plenty of room around the plugs and wires and plug changes should be even easier than stock. I will say I HATE removing those stock v6 manifolds and the 37 heat shield pieces you have to take off to get them out. I almost broke out the torch but refrained with the help of Budweiser and Sawsall (just one stripped nut on the head shield )! Enjoy!
Old Jul 12, 2007 | 01:59 PM
Chadder's Avatar
Those look pretty good. You could probably sell some over at FTV6.
Old Jul 12, 2007 | 03:55 PM
Tiago's Avatar
very nice Bryan.
Old Jul 12, 2007 | 03:58 PM
Phoenix 5.7's Avatar
looks good. i wish i could weld like that.
i agree with the stock headers. did a header install on one and the stockers were an absolute nightmare
Old Jul 12, 2007 | 04:12 PM
airattack111's Avatar
It was fun
Are you planning on selling any forward facing headers in the future? go on fullthrottlev6.com and post these up in the FI section they look sweet.
Old Jul 12, 2007 | 04:16 PM
Tiago's Avatar
I doublt he wants to go through that again
Old Jul 13, 2007 | 12:13 AM
99NMB's Avatar
gm could have made the v-6 easier to work on, i have done a couple of engine swaps, there one of the hardest 93+ cars to work on besides the LT1.
Old Jul 13, 2007 | 12:41 AM
darknessxyz's Avatar
Sent you a PM.
Old Jul 13, 2007 | 02:30 PM
Speed's Avatar
hahaha for sure
Thanks for the compliments guys. Hoping to have the passenger side done tacked up tonight perhaps or tomorrow. Then on to the y-pipe!
Old Jul 16, 2007 | 08:28 AM
Speed's Avatar
Built the passenger side header this weekend. It's a little tighter on the passenger side than before so the header is a little different. But it came out pretty clean. It was interesting snaking the collector through the heater hoses. On the last couple of pics, it looks pretty tight but there is actually about 3/8s of an inch between the heater hose and the collector. At worst, he might have to put a little exhaust wrap or a sleeve on the hose. Sorry the pics look like crap. Still using the trusty ol camera phone! I need to bite the bullet and get a nice camera but I never think about it until I'm building something.
Old Jul 16, 2007 | 08:49 AM
Tiago's Avatar
looking good. That heater hose might need to be re-ran but thats an easy mod.
Old Jul 16, 2007 | 01:29 PM
Looks like the two header facing different angle, am I right?
Old Jul 16, 2007 | 01:52 PM
Speed's Avatar
That is correct, they are not symmetric. The drivers side comes at a steeper angle. It needed to in order to provide more compressor housing clearance and the passenger side header had a clearance issue with the heater hose lines which prevented me from matching the angle. Plus the area to work in was not symmetric! Gone are the days of having enough room to make a matching twisted ball of snakes because you could stand in the engine bay to change plugs...
Old Jul 16, 2007 | 02:14 PM
Did you try to fit in the spark plug wire? Hopefully that won't make it PITA. They look very good and I DEFINITLY will PM you next week.
Old Jul 16, 2007 | 02:21 PM
Speed's Avatar
I'll see if I can snap a couple pics from under the car. The plugs will be a simple change and there is plenty of clearance for wires but they will not follow stock routing. The headers themselves install in about 15 minutes with everything out of the way. Having put headers on an LT1 fbody before, these are pathetically easy to install.
Old Jul 17, 2007 | 03:45 PM
pm sent
Old Jul 17, 2007 | 05:01 PM
99Z28LS1's Avatar
they look good. damn nice welds
Old Jul 18, 2007 | 12:17 AM
Speed's Avatar
Thanks guys! I got the majority of the ypipe put together tonight. Still waiting on flanges but they will get here tomorrow and I can finish her up! It looks close to the throttle body but it's really quite a bit of space there.
Old Jul 18, 2007 | 08:22 AM
kidcamaro98's Avatar
looks nice....yah my passanger side header is almost touching my coolant line also...so i heat wraped both of them and havent had any problems.
your gonna want to design some kind of support bracket from the Y pipe or the turbo...once those heat up and get a few hundred miles on them, they will wanna sag a little bit and eventually crack.
