New engine ?s
Old Jul 14, 2007 | 10:32 AM
nossty1's Avatar
Default New engine ?s
I just got my Low Cr 408 with patriot heads done and am trying to break it in before we throw it on the dyno. When I slow down and come to a stop it starts throwing a decent amount of smoke through the exhaust. When I start driving again most of it goes away. Is this just because the rings arent seated yet? All I was told was no boost while I am breaking it in. Anything else I should no? How many miles before I can put 14psi through it on the dyno for tuning?
Old Jul 14, 2007 | 12:08 PM
Phil99vette's Avatar
7 Second Club
Sounds like it could be pulling oil through the PCV system when vacuum is high. If the rings weren't seated it would probably smoke alittle all the time.
Old Jul 14, 2007 | 12:20 PM
cablebandit's Avatar
i have never had a ls1 smoke after the first 10 minutes of initial fire. Maybe its the turbo drain...
Old Jul 14, 2007 | 12:28 PM
nossty1's Avatar
I guess after about 5mi of driving it did start to go away. Then the cooling system wasnt up to the task and it got really hot and I had to pull off the road.
Old Jul 14, 2007 | 01:57 PM
lol...done all that...think all the air is out of the coolant system until a few miles up the road. Everyone is different. I start creeping up the boost the first day if oil pressure is good.
Old Jul 14, 2007 | 04:48 PM
nossty1's Avatar
Oil pressure is strong. Thank god. Why would the 408 need a catch can when just in vacum when my 346 never needed one, even in boost? Its not like I was pushing the motor or anything.
