What grade of oil are the you guys using-15psi and over?
Old 07-16-2007, 02:52 PM
LS1TECH Sponsor
DrTurbo's Avatar
Try diesel oil if you want max protection. Think of it this way, a diesel is a much higher stress engine then a gas engine. Static CR of 18-22:1 plus 35-70psi of boost with EGT's that climb to 1700-2000. Also you can't run standard motor oil in a diesel as it will burn off, so how much better is diesel oil . Something to think about
Old 07-16-2007, 03:10 PM
stevieturbo's Avatar
Diesel oils sometimes have detergents, that arent welcome in a gasoline motor.
Ive heard of people doing this, and the oil turning frothy. Although this was many years ago.
I run Motul 300V 5/40
Old 07-16-2007, 03:30 PM
LS1TECH Sponsor
DrTurbo's Avatar
Rotella though doesn't have them.....we have been running it on the race engines for quite sometime, and its available at Walmart now for decent price.
Old 07-16-2007, 03:34 PM
ddnspider's Avatar
Received 1,746 Likes on 1,304 Posts
dr turbo have u heard anything about the rotella degrading moly rings because of certain additives in it?
Old 07-16-2007, 04:49 PM
LS1TECH Sponsor
DrTurbo's Avatar
None so far. Some of the gas motors have almost 350,000 miles on it now from towing.
Old 07-16-2007, 04:50 PM
Mekkadon's Avatar
Originally Posted by NA$TY-TA
Same here Kev..... i change it quite often.....
how often, every 1500 miles?
Old 07-16-2007, 05:02 PM
NA$TY-TA's Avatar
About... some times sooner then that....
I usually buy the 5QT Jugs of Mobil 1 @ Walmart for like $21.. its cheap/// i usually buy 3 at a a time...
Old 07-16-2007, 08:29 PM
Turbo Addict
RICE ETR's Avatar
I don't run 15psi but still on the stocker so that's gotta count for something right?
Anyways, my brother works for a division of Ethyl that tests oils/fuels/additives/etc. Says Castrol GTX is probably the worst oil you can run...rarely does it pass their 3G test where they run an engine at like 80% load for 300 hours (I think those numbers are right)...it sludges up real bad and the engines usually never make it until the end before breaking.
He said Mobil 1 is the best synthetic but for an engine like mine; turbo, high bearing loads, & high heat, Rotella T is what i should run....so I do.
Old 07-16-2007, 08:42 PM
Moderator
FANTAZ28's Avatar
i use vr1 20 50 and change it every two track trips.... with minmal street miles. so i would say a few hundread miles max.
Old 07-16-2007, 08:52 PM
ddnspider's Avatar
used mobil 1 non synthetic for the breakin and switched over to Rotella after a few threads talking about this topic for boosted ls1s
Old 07-16-2007, 09:21 PM
2001WS6Vert's Avatar
Mobil 1 10w-30.
Old 07-16-2007, 09:53 PM
  #32
Frost's Avatar
>>>>>>>Rotella T<<<<<<<
Old 07-17-2007, 09:55 AM
  #33
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,148 Likes on 746 Posts
Link to Rotell T info:
http://www.shell.com/home/Framework?...ellamulti.html
I had never heard of it before, thanks for info guys.
I've run mostly 50 weight oil.
Old 07-17-2007, 11:02 AM
  #34
LS1TECH Sponsor
DrTurbo's Avatar
Here is the one we use....
Syn. Rotella
Old 07-17-2007, 11:04 AM
  #35
NA$TY-TA's Avatar
50 weight oil for me would shoot my oil pressure thru the roof..
Im already 100+ psi @ WOT.
Old 07-17-2007, 11:22 AM
  #36
SonofaBish's Avatar
Syn. Rotella
I just started using this as well in my LT1... and will be using it in my TT LS1 when its done....
Over the years i've heard nothing but great stuff about teh Shell Rotella T ... i'd always been hesitant about buyign it b/c its so cheap, but i've never heard a bad thing about it!!! Its been raved about on the motorcycle forums, and most despise putting car oil in a bike
Old 07-17-2007, 11:24 AM
  #37
LS1TECH Sponsor
DrTurbo's Avatar
Yup, if you want to beat the crap out of a turbo engine....its the best thing to use.
Old 07-17-2007, 05:35 PM
  #38
Turbo LS1 SS's Avatar
Rotella T for break-in. its high in zinc and seats the rings. then i use VR1 20-50, and change it bi-weekly. hastings filter
Old 07-17-2007, 05:45 PM
  #39
ddnspider's Avatar
Dr turbo where do you get the blue container synthetic?the only 1 ive seen is the 1 that PSJ linked to and been running that
Old 07-18-2007, 09:57 AM
  #40
LS1TECH Sponsor
DrTurbo's Avatar
Walmart now carries it
Quick Reply: What grade of oil are the you guys using-15psi and over?
