H/C/I want boost
Old Jul 16, 2007 | 01:37 PM
john563's Avatar
Default H/C/I want boost
I'm heads,cam and ported fast with a 10.75:1 comp. Iknow its high comp for boost,but can i run low boost til i swap heads.If so how much and what gains wil i get.If its not possible I'll just spray.
Old Jul 16, 2007 | 01:51 PM
sprayjunkie's Avatar
My buddy just added a Procharger to his H/C/I LS1.
He was at about 10.2:1 CR, and we added 7psi to that.
On motor, it made 445rwhp, on boost we saw 580rwhp, with more to come with bigger injectors.
Do it!
Old Jul 16, 2007 | 02:04 PM
john563's Avatar
Do it!
thanks for the info
Old Jul 16, 2007 | 02:34 PM
Cchris1109's Avatar
depends on what kind of cam it is though, if its a positive overlap you may not see much boost.
Old Jul 16, 2007 | 07:08 PM
john563's Avatar
Tr 224/224 563/563 112
Old Jul 16, 2007 | 07:49 PM
EPP's Avatar
EPP
http://www.exoticperformanceplus.com...Car.php?car=46
10.9/1 on this LS2.
Your cam will work, it will just bleed off a little boost. With your heads and cam I'd shoot for 6 psi of boost on an unforged bottom end with your heads and cam. Bob
Old Jul 16, 2007 | 08:29 PM
john563's Avatar
Mods:
TSP stage 2.5 5.3 heads,tr224/112cam, ported fast 90/90, lt hedders ory,dynomouth,rpmlevel4tranny,TCIssf3500stall,Pst driveshaft(from bob of coarse) moseraxles,Bmr adjt tourque arm lakewood lower control arms,42lbinjectors,racetronix hotwire/pump
Katech rod bolts going right now with clevite bearings.My car is a 98,so heard that the bolts can go bad on older models so i replaced them before it has achance to go
Old Jul 23, 2007 | 05:01 PM
john563's Avatar
I was thinking of adding 5lbs of boost with what I have now til i swap heads and pistons
Old Jul 23, 2007 | 07:19 PM
98redorangeta's Avatar
John you would be ok on low boost the problem is when you want higher boost for a built motor your gunna max out the turbo/sc and your gunna end up buying another one if your fine with that then go for it if you want to save some money wait till you build a motor.
Old Jul 28, 2007 | 09:00 PM
john563's Avatar
Marc
I'm seriously considering it in the next couple of months.Low boost on what I have.Depending what parts and labor will cost.I really only want to be around 500rwhp.Most likely I'll get more,even on low boost.Thats plenty for a street car.You do tune turbo cars too right?
Old Jul 29, 2007 | 05:57 AM
dadem0n's Avatar
Isn't this cam usually one of the ones recommended for boost anyway?
Old Jul 29, 2007 | 01:13 PM
nvmy2000ss's Avatar
No. I wouldent think so. It may be the one they have on a 114 lobe seperation. They both work but apparently you bleed of some boost with the 112, but I have never seen how much power you would loose between the two cams. This would be interesting to know though.
