What trans fluid are the big boys running
Amsoil super shift ART, I had my TH400 built at a shop, I had them get me a trans cooler and the oil for it all in one shot, its expensive stuff, but thats what they want me to run thats what ill run.
Originally Posted by smokinHawk
so what grade tractor fluid? or is there only one available
Rossler told me to use Traveler Premium 10-20W. I can get you the part number off the bottle if you would like. It comes in either 1 or 2 gal containers at Tractor Supply.. i forget which one it is.
Nah, in the blue 1 gallon jugs.
When we got our trannies from Rossler way back... He told me just to run cheap dex 3. So there you go...
PSJ, I've been busy building cars and racing. You know, when you take your car to the track and make passes. LOL
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Originally Posted by twinturboz28
I've been running hydraulic fluid.2 years in the low 7sec range at 3200lbs,havent replaced 1 part in the trans.
Thats why were going to run it in mine also...... Go home unless your still there working on the car
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
****, Head... LOL
If I remember right Rossler had told me he would run the tractor fluid simpily because its easier to tell when its starts to get burnt and it will hold up better to the heat. Its probably just personal preference as it seems everyone in here runs one or the other and has not had any problems.
#32
6 Second Club Moderator
Amsoil super shift. Never had a problem, held up in my Rossler th350 and my 400. Not to mention the abuse it gets in my truck!!!!!!!!!!!!!!!!
John, I get all my stuff at dealer cost, you could have it for the same.
#33
Originally Posted by MIGHTYMOUSE
i use dex 3 cus its what it says to use in the owners manual.. i figure they have some clue what the right stuff is.
#35
Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
PSJ, I've been busy building cars and racing. You know, when you take your car to the track and make passes. LOL![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
oooooooooooooooooowned!!!
#40
Originally Posted by 72chevelle6.0
I have a trans that I am going to change the fuild in can I use tractor fuild with the TQ still having ATF in it?
We usally put in a QT of Reg trans fluid to add color to the Tractor fluid since its clear....... that way we know if we have a leak....
Kyle
