Wastegate Troubles?
The positioning of the WG off his turbine feed looks ok to me, thats almost exactly how I have mine and I don't have any creep whatsoever! this is assuming the fabrication under the wrap is good and the junction/transition on the inside of the turbine feed pipe is very smooth.
you can see here where the wastegate attaches on mine
how much pressure did you apply to the WG in order to get it to crack open like the diagram you have above. You might already know this but a 12psi spring won't open up @ exactly 12psi. It will start to crack open more then likely around 8 or so psi and hopefully be fully open by 12#.
Twin WG setups on single turbo applications are a very common thing. small motors running huge turbos do it all the time to control boost. this works especially well with twin scroll turbines. There is alot of science behind it, most of which I don't understand, but the gist of it is that if you can get the cylinders that fire together to merge into a single collector, usually 4 into 1, and put one WG on each collector you'll create a scavaging effect and increase the efficency.
BTW, much props to you for doing all your own fabrication & trouble shooting.
Thanks for the compliment, its been about a 6 month project from start to finish. With a help of a few friends we did all the work here locally.
I had 3 of these and sold two. I held onto one for a good friends project but he's telling me now to sell it. Brand new in the box.
https://ls1tech.com/forums/lsx-parts-sale/708484-hks-gt-wastgates-sale.html
That's what I'm basing my pricing on.
