FMIC Design Flaw
that is all.
I have EPP's FMIC. Having it installed prior to my supercharger, I noticed NO difference in engine temps. Once the supercharger was installed, then I noticed some engine temp increase. I combated it by adding a little more material to the air dam to the radiator. It seemed to help about 10 degrees. I don't think my FMIC is robbing the radiator any, I just think the car runs warmer from the supercharger. Then again, maybe its like Bob said, that the EPP kits don't seem to have issues.
Here's how the car looks normally, when your not looking at it from such a low angle with a bright light.
Keith
Hi Keith. I guess I am missing some things. I have the stock C6 Kit from Procharger. Don't get me wrong here, I love the power from the kit. What can I do to get more of a fresh source of air? Do you believe I can get better fans that the stock ones?
On a C6? I am pretty sure the radiator gets air through the big opeining in the front facia. I'd be shocked if this isn't the case.
Prepare to be shocked........
and its almost the opposite with the vertical IC, that way the metal frame is directly behind it and keeps air from flowing all the way through, so unless u cut out the front metal frame, that will happen anyway
When it comes down to it, this will never be proved one way or another unless specifically, you or someone else tries their setup BOTH ways and sees which is better at cooling the IAT's. Until then, we may just have to agree to disagree
Front Lisense Opening
Front License Cover
As far as fans, there many that flow more than the stock fans. To use them though, you will need to modify the rear fan shroud or make a new one. I will be added a bigger radiator and better fans here in a bit.
Keith
and on top of that i have very high velocity air underneath the vehicle flowing directly over the cooling fins, much more air then the inside of the bumper sees
I got proof. I road race mine. Nothing tests a cooling system like full throttle between 30 and 135mph and back for 20 minutes at a time. Then again, it does get a little extra cooling when I slam on the brakes for the next corner.
Personally, I still fail to see how it will be as effective as a FMIC sitting upright. Think of how much wind comes at your face and in your car going 55 MPH with the windows down. Now consider how much wind would be in your face and in the car if you were travelling 55 MPH with no front windshield. Air flow is all the difference in the effectiveness in the intercoolers ability.
Again, both systems are proven to work effectively, but without trying each system seperatly in the same car, there's no way to prove that one is better than the other.
Front License Cover
Keith
That is very cool! thanks for sharing the pictures...it certainly gives me something to think about that is for sure. I'll talk to my tuner about this too.
