Velocity rings for Superchargers-gain 1 to 3 psi?
Originally Posted by Got Me SOM
140 bux is kinda pricey, i was hopin it would be more like 80. I wonder if they have documented gains or are just saying it will work. By narrowing the path of the boost and smoothing the flow. I see it increasing velocity. Its pricey cause they are made from billet or something.
I think there are 2 for sale now, not sure on the inlet size though
OWN3D BY MY PROF!
Originally Posted by Alex @ CMS
if the blower is able to take in more air due to there being less turbulence then the boost will increase. Blowers have a set speed and do not bleed off boost like a tubo, the more air it can take in the more that it will compress.
I think it just gives the blower's inlet a greater surface area of possible air to intake. When you trap them with those rinky dink procharger intake hats they're only recieving as much air as that tube's volume. With the stack you're going from a contained volume to a larger open volume. It seems like it would do something. I don't know about an extra 2 pounds of boost though.
LS1Tech Sponsor
The ring's work
But
You either run no filter or a huge inlet pipe for no restriction. It helps smooth the airflow into the blower which pulls more air. Now,we are not talking a gain with a 8lb blower setup.We mostly see gains in our Renegade cars that push 20-30lbs of air.
A benefit for your Vette? Doubt it since it seams to have belt problems now.
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
But
Originally Posted by Slowhawk
The ring's work
But
But
Originally Posted by eb02z06
......Right now i'm running a 6" inlet inverted cone S&B filter?
Originally Posted by NemesisC5
Whats the S&B part number Bro?...Air filters and inlets for blowers have been a topic of interest to me as of lately
http://vertexnow.com/Verocious-Motor...4-Outlet-R0217
It's 6" long-I think i might try out the 9" one-i mean it can't hurt?
This is the one I'm running bro:
Thanks Bro, saved it under "Corvette Air Filters" in my Favorites List. I am information junkie and OCD Modaholic
LS1Tech Sponsor
Thanks Don-i was waiting for someone who had renegade experience to chime in. I got the slip issue sorted-no more slip-I had a belt one size too big. So are the Renegade guys running inlets bigger than 4" or none at all-would it be better for someone like myself to run a bigger airfilter? Right now i'm running a 6" inlet inverted cone S&B filter?
#34
Is it the location of this bellmouth that is supposed to help, or just the fact there is one in place ?
I run a short 45deg Silicone pipe, to a 4-6" bellmouth and a big filter ( but just bought a bigger one though
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I still couldnt manage to make more than 20psi on my YSi.
