Power question. Turbo guys come in!
another thing you might want to try is a pressure test to see if you have any leaks in your charge piping.
I am see 15psi at the manifold so I doubt there is a leak that is affecting it this much.
if you said you pulled the boost reference off the WG and felt no difference what so ever I would suspect there is a problem with the WG not staying shut. with the Tial units there is a fire ring @ the base where it would connect to the manifold/collector, often times that ring is left off and the result is simular to what you are experiencing.
also a boost leak test is never a bad idea. it takes a short time and you would be really suprised what you would find.
I was just hoping someone had a similar situation and could shed some light on the situation. I am sure once I figure it out it is going to be something stupid but I will try anything to get to the bottom of this.
The spring is set to 6psi and I saw 15.5psi with it pulled.
again I'll ask what kind of WG are you running?
I am starting to think the push rods are too long. I am going to pull the valve covers and check lifter pre-load. I was told to just run the stock ls1's I had. I was rushing to get it done and to my stupidity I never double checked them.
It is the only thing that makes sense so far. I will keep you guys posted. Thanks to all that helped! Last edited by phildo; Jul 30, 2007 at 08:56 PM.
Plenty of boost going in but no power? It does kinda sound like a valvetrain problem.
1- the valves are floating or the pushrods are too long.
2- both 02 sensors in the 1 crossover pipe in a no-no. 1 bank could be way off from the other which causes the car to run like complete crap.Have seen it many times while closed loop tuning.Move 1 02 to the downpipe.
3- The turbo is not a back pressure problem at such low boost but the rest of the exhaust could be.Run an open downpipe to check.
4- the dyno could answer alot of questions and save time.
I have the day off today so I am going to get to the bottom of this. I will keep you guys posted.
Thanks for all the good suggestions!
You say timing is steady at 16 degree's and A/F is 11-1 read from a wideband?Unless the tranny is slipping I'll say it's valve trane.
