LM Speed Maggie Kit For F Body
Originally Posted by 97 Z Me Go
What map sensor is sposed to get used with this? Any part numbers? Is it from a cobalt ss cause i NEED ONE NOW to get the car running.
__________________
2002 B4C Black On Black 6-Speed
2006 SS/SC Cobalt Silver With G85
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
Sounds good. Hopefully the rain will go away otherwise we can wait becuase i think traction is going to be somewhat of an issue
Hey Kyle,
Sorry I didn't send it with your other parts, I was supposed to get hem Thurs, but they didn't come, so I sent the box without it. I still don't have them, but as soon as I do I will overnight one to you. The GM PN# is 12580698
I think it's the same one as in your Cobalt SS, the sticker is brown instead of blue. If that's what you have, take it out of your other car and I'll replace it when I get mine.
I'll call as soon as I get them, hopefully tomorrow,
Ed
#33
Sweet. Ill be wating for it. Got the car dialed in tonight. Wow is it a head turner with the cam(ms4) and that blower wine! Needs a little bit a idle tuning but otherwise its a blast to drive.
Kyle
Kyle
#37
The magnavolt was mounted inside the drivers fender. We attempted to hide everything we could to keep the install clean as possible.
The hood had to be cut where the top of the TB is. I was not able to cut anymore off the TB to make clearance as the IAC screw and diameter would not allow any more material to be taken off. So there is a square hole that comes threw the hood right after the screen on the scoop.
#39
Originally Posted by yotaman96
Looks good man. Are you not using the magnavolt? How did you run your pcv hoses? Did you have to do any cutting to the hood?
Slowc5 summed it up pretty much but as for the pcv i only ahve that one on the passenger side right now. Tonight im putting a different valve cover on and going to cross it on the back of the valve covers and then keep the one on the front passanger side to the throttle body. I will be adding a catch can but i dont have 150 bones to throw out the door on one just yet.
Kyle
