Hp Performance Turbo Kit V Sts
I ALSO TALKED WITH TRT PERFORMANCE THAT SELL STS. FOR EXAMPLE WITH THEIR STAGE 3 TURBO KIT I WOULD ONLY MAYBE GAIN ABOUT A SECOND OFF MY QUARTER MILE. HE TOLD ME IT WOULD TAKE MORE THEN JUST BOLTING ON A TURBO KIT AND A TORQUE CONVERTER TO GET INTO THE ELEVENS OR EVEN HIGH TENS. IS THIS SO , DOES ANY ONE HAVE A HP PERFORMANCE KIT IN THEIR STOCK LS1 IF SO TELL ME ABOUT IT AND THE TYPE OF PERFORMANC YOU GET. AND ALSO SOMEONE WITH STS SYSTEM TELL ME ABOUT WHAT YOU THINK OF YOUR NEW KIT AND ITS RELIABILITY? THANKS FOR THE HELP GUYS.
Theres much more in getting ot the 10's than power.. Suspension have alot to do with it... Also You would need a 12bolt or 9" rear to be able to leave on slicks...
I have the sts turbo kit, and running 7psi you can expect about 130 rwhp gain..
I dont know much about the HP kit, but your not getting into the 10's with either base kit and a stall...
Ive been done this road, and learned that when they say take the cost of what you think your going to spend and add 50% to that, thats very true.. Ive done it!
Billy at TRT is correct! Of course hes not known around the country for no reason..
Now, if you WANT to get into the 10's and have the cash go for it!, but I wouldnt be dissapointed if you bolt on an STS kit @ 7psi and run low 12's!!!!
But I did read the post above, which stated in it the STS kit. If 10s is your goal, look elseware. If the STS even has the capability to go that far, with any turbo, it certainly isn't going to be fun or enjoyable to drive anywhere other than the track.
