Need some help...turbo troubles
Old Aug 12, 2007 | 12:00 PM
turboiroc's Avatar
Default Need some help...turbo troubles
running a t72 w a q trim on a 383 chevy 38mm wastegate theres a 20lb spring in there so it should make 20 lbs of boost right? it doesnt i get about 9 lbs of boost and like 40lbs of exhaust pressure. im blowing header gaskets out like crazy and turbonetics guys say its good for over 800 hp somebody help!
Old Aug 12, 2007 | 12:40 PM
DrTurbo's Avatar
LS1TECH Sponsor
T72 is too small for a nice flowing 383. Check for boost leaks though....if you have a leak, that would explain the high exhaust pressure with little intake pressure.
Old Aug 13, 2007 | 10:26 AM
RW99's Avatar
What type of BOV? Lose a reference line to your BOV and you'll see some boost, but below your wastegate pressure.
Old Sep 10, 2007 | 07:37 PM
turboiroc's Avatar
Default sickly fast
its been running alot better lately i leaned it out alot and fixed exhaust leaks. oh and i was reading the gauge wrong! duh its got like 25 psi on the exhaust. putting the a 1000 fuel pump on and cranking the boost up then its off to wildwood hot rod fest to put it on the dyno 600 hp here i come!
