APS f body install thread, tips,tricks,pics,etc.
calongo - you might be able to use a 5th jackstand (truck stand or stand on blocks) to support the engine while you swap the k-memeber.
Brains, I wish I knew you were going to be in KC a few weekends ago. That would have been cool to catch up with you and discuss install plans of these kits. We raced Friday night. I was on the Motown Muscle crew with the Thunderstang! Maybe another time. But by then my kit should already be in the car.
Painted my lettering Orange to match the car, so ready to go!
And today I have a baby shower to go to at 3pm so I'll only get about 2 hours of work time in and then I'll head back out to the shop.
Question. so in order to pull the tank I remove the exhaust and unbolt the clamp straps and it will slowly fall down. Is there enough room for the lines to come down with it so I can get my hand in there and disconnect them?
yes there is enough slack in the line...but I guess it depends on how high ur car is going to be. I had mine not too far off the ground when I put my racetronix plug and play in....I love that kit.
oh, btw...u need to get ur priorities in line. getting this kit on ur car should be first over everything. I'm sure the wife and kids will understand (if u have any)
I just unpacked all my APS stuff and took inventory. All the parts seem to be here (comparing to the BOM on the APS site). I won't be installing until winter.
Peter
Peter
This may be a dumb idea, but I admit, it has crossed my mind.
Has anyone thought about modifying the hood close to the firewall, down low where you can not see it, to allow air to pass through under the hood from the Ram Air inlets to the back of the hood allowing heat extraction from in engine bay? If it’s done right you would not be able to see it except when you’re in the car. Heat should be forced/sucked up over the window while you're driving.
Stupid idea???
