402 twin turbo mistake ?HELP!!!!
Post up your hpt file, and a log file. You can do that right here, you don't need a host or anything. Just reply to this thread, and right below the "submit reply" button is another box titled "Additional Options". There's a button in there called "Manage Attachments". Press that, and it will allow you to add files from your hard drive as attachments to your post. Then we can all take a look and see if there's anything obvious.
Personally, I think it's in the tune, because of your description of how it blubbers/pukes as soon as you see some boost, and also your description of the piston tops.
Oh, and get a new sensor.
Oh,I see you are in St pete,is that goofy Tiger house still there ? You do have a 2bar sensor right?
I have a friend that spent weeks fine tuning his timing and PE tables to help combat turbo lag. His car will now insta-boost with an STS setup.
