Speaking from experience, doing it on the car is doable, but I would not recommend it. There really is a ton of metal going to get inside your oil pan. It is such a large hole, and there are so many shavings produced, you can't help but get some in the oil. I even took my oil control tray in the sump out to celan out the shavings under it. If your confident that the filter will pick them all up, which may be the case and all is good then I'd go for it. But I guarantee your will get some inside the oil pan no matter how careful you are.
100%^^
An engine needs to stay to stay surgically clean inside, like the human body.
haha man where you been? i thought maybe you were hauled off to the funny farm or something.
school and holidays, they let me out on good behavior for a couple weeks
I need to change where I'm putting my return do to the crossover pipe being in the way , can I put the return I the front of the oil pan where I'm pointing ?
That's where mine is-it takes some careful meas so the fitting clears the balancer
