help with procharger
Old May 27, 2003 | 06:59 AM
snkchrmr's Avatar
Default help with procharger
I put a p1sc with the #5 pully the problem I'm having is under normal driving it is throwing out a lean code on all 4 o2's I think the code is 170 or 171 cant remember exactly right now but the car has had no programming it was supose to be a striaght bolt on kit but it has not worked out that way its not an vaccum leak or anything like that b/c I can take the belt off and it want throw out the code well if anyone can help please do so cause I'm about fed up with this crap thanks
Old May 27, 2003 | 07:10 AM
AzzHauler's Avatar
From: Richmond, VA Where fast cars, well......are hard to come by.
Default Re: help with procharger
Got any autotap data?
Old May 27, 2003 | 08:09 AM
snkchrmr's Avatar
No I really don't have anything I tried to get it hooked on the dyno to see what the A/F was doing but he wouldn't put it on there b/c it was already throwing out the lean code I would get LS1 edit but I dont know that much about it so I dont want to screw it up any worse and no one around here can program it I'm here in NC Charlotte area
Old May 27, 2003 | 09:12 AM
funeclown's Avatar
I had the same problem at 5#'s. Your safest bet would be to get it dyno tuned. I have not had a problem since I had Cartek tune my SS. Before the tune I upgraded to 7#'s. No light & it runs a hell of alot stronger
Old May 27, 2003 | 09:15 AM
funeclown's Avatar
If nobody is available in your area, you can try mail away ECM, but I would absolutely rule out the unavailability of someone in the area before
mail/tuning
Old May 27, 2003 | 11:52 AM
snkchrmr's Avatar
I'm going to put it on the dyno today to see how lean it is wondering is it safe to drive till I can find out who to program it as long as I dont get into te boost?Right now I have the belt off to drive it
Old May 31, 2003 | 04:04 PM
glitch77's Avatar
I have *heard* that running a pully-less SC is fine mone than a few times. But dont take my word as the gospel, as I have no SC in my sig yet.
