Unpressurized cooling system for high hp race cars?
Lot of tracks these days wont let people run antifreeze or water wetter in 9.90 or faster cars anyhow. I wouldnt run anything but water in a race car, antifreeze is some pretty slick stuff. If you get over 212 on a pass in a drag car something is wrong. I seldom see over 200 even on 95 degree days at the track after back to back 1/4 mile passes.
Thats exhaust heat I would assume, in general its good to get the oil temp up on any engine before making passes but leaving the line over 200 is probably a little hot and thats the only way I could see going above 212. I would think 170-180 water temp is around the best place to be on the line with any setup.
Originally Posted by gnx7
Evans NPG coolant runs at zero pressure. The liquid is more viscuous and pulls heat out from the heads/block better than other coolants.
"Use of a 7 lb. cap on “waterless” system is recommended for racing, street rod and performance enhanced vehicles. For applications where 7 lb. cap is not available, standard cap may be used. All stock – factory original computer controlled daily driven vehicles are coolant change only – no system changes are required."
they go on to recommend a 0 or 7psi cap on coolant overflow tanks.
but the basic point is correct, that evans is not as prone to cavitation, vaporization and has a lower surface tension so you're less likely to have hot spots, which all adds up to not needing the same pressure in the system that normal coolants need.
Jim
im assuming the reason behind this is less parasitic drain on the motor correct?? Since the water pump isnt pushing water thru a pressurized system??..You could just run an electric water pump and get the same benefits...
