LS9 Supercharger
So far they have given us:
-The "Hot" and ASA cams ... which kinda suck if you ask me (I've got a hotcam so I can rag on it)
-L92 heads for DIRT cheap
-L76 intake/Tbody/Rails/Injectors for DIRT freakin cheap
-LSX block which is the ultimate gift to us
If they could give us a blower for dirt cheap then they would once again corner the budget minded performance sector of the industry. Sales of a blower kit shouldnt hurt the overall image of the ZR1 or CTSV because only hard-core folks who are willing to tear a Gen III engine "with all them dang sensors n' computers n' hoses" to pieces could actually make use of it.
The only thing that I could see being a problem is if the baseline vette and the ZR1 have a price difference that far surpasses the price of the supercharger kit. Even the people who can afford the ZR1 will still pick up on some rumor of how the standard vette is only a $2000 supercharger away from being a car that costs $30k or $40k or what ever the difference is. That could be our biggest obstacle.
But I don't see GM letting you be able to get your hands on one of these blowers very cheap, at least not initially.
If they did release a blower I imagine a sponsor would take it upon themselves to fab up a "kit" that would work for us. I wouldnt bet that GM would do the leg work there.
2300TVS Blower should be good for +900HP, the blower only is $6000us. It probably could be adapted to the Magnacharger Manifold with the proper drive shaft. But this would be very expensive.
Eaton took back their exclusive from Magnuson so this blower can be adapted by anyone now.
There is a blower from Australia, Harrop.au, however there are in my opinion some functional issues with that design.
It will not fit on a C5 or the F-bodies, the blower drives are behind the Block so those pullies will almost interfere with your built in radio! Very Very poorly thought out. Compact design was not in that discussion.
Next, the Front drive pulley is the first device from the crank pulley, this is why the procharges are not reliable. They had to add a 10v belt set up to keep the belt in place, but there is still a traction issue.
I have basically given up on the availability of this blower because people like John Lingenfelter are not around to champion the cause.
The easiest solution would be parts directly from GM for a kit, This would also preclude anyone from building a unique kit, who would want to go up against GM as a source?
SDPC, if you've got the full scoop on this, then FOR THE LOVE OF GOD let us know what's goin on!
