Finally made some 2007 hits, 9.44@144 and 1.35 on DR's
Old 09-14-2007 | 06:26 PM
  #61
FANTAZ28's Avatar
Moderator
Yeah I have to look at the LCA's, but so far the car was working with just the adjustments we made with Madman's advice.
lol i thought your lca were fine?
Old 09-14-2007 | 10:37 PM
  #62
Pro Stock John's Avatar
LS1Tech Co-Founder
Maybe I would have gone 1.30 instead if they were right.
Old 09-25-2007 | 04:56 PM
  #63
LS1Tech Co-Founder
Chasing a few leaks right now.
How are cars like the Speed Inc. shop car plumbing braided line for the vacuum lines?
Old 09-25-2007 | 05:03 PM
  #64
Websy21's Avatar
Just caught this post now, you had some great progress b/w every pass. You keep that up and you'll need wings. I wish I could get a second faster every run!
Old 09-25-2007 | 11:03 PM
  #65
NA$TY-TA's Avatar
John im using -4an line with NPT fittings to AN fittings.... works just fine... got rid of all the rubber hoses because we kept having problems with them coming off.
Kyle
Old 09-26-2007 | 12:35 AM
  #66
Specialized's Avatar
I think that is the point @ which fixing even small things on the car become a very costly endeavor.
Awesome runs though, looks like the car is going to be a killer at memphis!
Old 09-26-2007 | 01:12 AM
  #67
Websy21's Avatar
no ****, steel braided vaccum lines. Too rich for my blood, lol
Old 09-26-2007 | 11:14 AM
  #68
LS1Tech Co-Founder
Tapped into where, and also any links to the push-on fittings or whatever they are using? My buddy was thinking -3 line.
My car has boost leak/issue somewhere, might be on the cold side somewhere. It's making very little boost, and while I have an exhaust leak at the passenger mani where it bolts to the uppipe, Kurt was saying on the phone that that would not account for the minimal boost the car is making now.
We'll get there.
Old 09-26-2007 | 12:05 PM
  #69
NA$TY-TA's Avatar
We'll get there.
John we use those too..... Ill get ya a link where we get them.... thework awsome....
Old 09-26-2007 | 12:20 PM
  #70
JMBLOWNWS6's Avatar
I am getting push lock tubing and fittings for my vac lines.
Old 09-26-2007 | 12:42 PM
  #71
LS1Tech Co-Founder
I guess I need some sort of distribution block? Pics? Links?
Old 09-26-2007 | 01:31 PM
  #72
JMBLOWNWS6's Avatar
I can only find the cheap white ones on the net. Havent found the black ones like I got in town local.
Old 09-26-2007 | 01:37 PM
  #73
JMBLOWNWS6's Avatar
Ok here yea go
Push-In Fittings
Old 09-26-2007 | 01:40 PM
  #74
NA$TY-TA's Avatar
John they make T-Fittings in them...
Those are the ones... replied to your PM. Ill have the info in just a lil bit.... im at home and the info is at the shop.
Kyle
Old 09-26-2007 | 02:44 PM
  #75
427's Avatar
427
This is some 6mm hose stuff I use on wastegates. It needs to be routed properly, but it has very low weight.
I buy it from McMaster carr
Kurt
Attached Thumbnails Finally made some 2007 hits, 9.44@144 and 1.35 on DR's-2007_0926push-loc0007.jpg
Old 09-26-2007 | 02:51 PM
  #76
FANTAZ28's Avatar
Moderator
same stuff i used on my car, no issues yet.. super light , super easy and looks very clean. as long as you route it correct like 427 said you shouldnt have any issues.
Old 09-26-2007 | 03:28 PM
  #77
NA$TY-TA's Avatar
Kurt
Exactly..... i was just gunna post thats who we get it from too.....
Old 09-27-2007 | 11:27 AM
  #78
JS's Avatar
JS
Good for u John,Keep at it
Old 09-27-2007 | 11:31 AM
  #79
LS1Tech Co-Founder
Sweet McMaster Carr is local to me and easy to work with, thanks every and thanks Intmd8 for the help in pms. I also want to think FANTAZ28 for all the help, it's been very hard for me to get out to track and he's helped me get the most from the track visits, from comparing his experiences to mine to troubleshooting and staying focused at the track.
I'm hoping to put aside all of Sunday to work on the car, hopefully nothing is broken though I can hopefully test the wg and make sure it's not stuck open.
Old 09-27-2007 | 11:45 AM
  #80
DMH Fabrication's Avatar
I'm supprised people are having problems with standard rubber hose and barb fittings(look just like the push lock fittings but with npt threads on the other end and not a an fitting). I almost always use barb fittings and put one zip tie on the hose. I've never had an issue with them coming off. I've ran 35+ psi on some of the imports we've built and no lines ever came off.
Quick Reply: Finally made some 2007 hits, 9.44@144 and 1.35 on DR's
