T76 Turbo. Stock LS1
I have a 1.08 with my 88mm, and my car doesn't turn on until like 5000. If you already have that turbo, get a much smaller exhaust housing, so that you can make some sort of usable power.
I've gone 7000, and I'm going to turn it higher next time to compare... so 7000, 7300, 7500, and maybe 7700 but I'm a little skeered of 7700. None of the 155-170mph turbo guys on here turn their motors less than 7400 rpms that I can tell.
Originally Posted by DrTurbo
I'm still trying to figure why he says the compression is low enough on a stock motor? Does he know what the compression is on a stock LS1??...lol
Originally Posted by IMD
can you guys freakin read? i wasnt replying to the guy with the stock motor, i was replying to the guy with 8.5 forged motor. jesus christ.
you just told a guy that 20psi on his setup is ok with pump gas. Not only can I read, I can speak from mouth instead of my other end
You might pull through 1 gear at 20psi, but try putting together a whole pass or two (pulling through all of your gears) and see what happens on your own **** before you tell someone else to do it.
Ok the exhust housing that I have is located on the left of the pic.
Which is called a on center. The one I think you have is the one on the center of the pic.
If you dont have any of the hot piping done then housings should not be a issue. My personal views is this one would be better as it gets rid of the Vband style which you have.
We see a fare share of broken piston/engine pics from guys who really pushed the limit on pump gas LSX here. These same guys seem to not want to run 93 pump again with the boost up. Do it to YOUR own engine but it seems nukin futs to me.
