O-Ringed Block: Head Question
Old Sep 16, 2007 | 08:24 PM
Twin76mmTA's Avatar
Default O-Ringed Block: Head Question
The Backround:
I've got a Iron block that has been O-ringed with Stainless Wire, the Diameter of the the 0-ring is 4.220
The Question:
I want to use the a large bore 4.125 head like the new Warhawk Ls1x, Edelbrock Terminators or My ported AFR 225's.
With a 4.125 Copper gasket is .095 to the Stainless O-ring enough material to insure a a proper seal against the copper gasket?
Cliffnotes:
Is .095 Enough Gasket material to seal between the cylinder and the O-ring.
Old Sep 16, 2007 | 09:51 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
I'm Running 4.0 bore heads on my 0-ringed motor but don't know what my o-ring is set at.
Old Sep 17, 2007 | 12:53 AM
Jammer's Avatar
I use Fel-Pro graphites with my o-ring set up.
Old Sep 18, 2007 | 01:27 PM
Twin76mmTA's Avatar
Anyone else?
Old Sep 26, 2007 | 11:36 PM
LS1curious's Avatar
the answer is maybe. Are the heads going to be cut with a reciever groove ? If so then yes if not then no.
Enjoy.
Originally Posted by Twin76mmTA
The Backround:
The Question:
Cliffnotes:
Old Sep 27, 2007 | 07:22 AM
1INSANEGTO's Avatar
Having the block and heads oringed help with lifting heads?
