Need Manual Boost Controller Directions. (Turbonetics)
Old Sep 18, 2007 | 07:43 PM
JAvenger007's Avatar
Default Need Manual Boost Controller Directions. (Turbonetics)
Searched around but no luck, and turbonetics isn't getting back to me.
I just need to know which direction the arrow on the controller should face. Does it face (or flow i guess) toward the wastegate or towards the manifold.
Attached Thumbnails Need Manual Boost Controller Directions. (Turbonetics)-boostcontroller.jpg
Old Sep 18, 2007 | 10:49 PM
Turbo Tech's Avatar
Dam its been a long time since I looked at one of them. I will send you a diagram tomorrow but if memory serves me correctly. The arrow is the air flow from the valve to the top of the wastegate. You can tee the line you have going to the boost side of the wastegate that line would be the inlet to the boost controller. Out of the controller to the vacuume side of the wastegate. The should be two 1/8 plugs to seal the other two holes.
Old Sep 19, 2007 | 09:51 AM
Not sure i follow you there. So the unit doesnt just splice into the line going to the wastegate? You have to run a line to both ports on the wastegate (top and side?)
Old Sep 19, 2007 | 10:54 AM
edit: figured it out, basically just as you described Thanks for the help. Ill leave this pic up in case anyone else needs to know.
Attached Thumbnails Need Manual Boost Controller Directions. (Turbonetics)-boostcontroller3.jpg
Old Sep 19, 2007 | 11:52 AM
Turbo Tech's Avatar
Old Sep 19, 2007 | 02:16 PM
looks much better than mine
Thanks again for the help. Should be up and running in a few minutes.
