Boost Spike Issues - HELP!!
- Dug
How long are your vacuum lines to the actuators? Are they both the same length?
Also, make sure that the actuators are opening at the same psi (using a mity-vac or something similar).
Scott
- Dug
My vacuum lines that run to the actuators are exactly the same length. Also, I don't have anything else tied into the vacuum line that goes to the control solenoid...and I made that line as short as possible.
You might want to try making the lines the same length and taking all of the accessories off of the line that goes to the 'IN' side of the boost solenoid.
Also, do you have the Sharpness setting on the controller turned all the way up?
- Dug
Would you be able to draw a diagram of how yours is setup Scott?
- Dug
I will email it to you since I don't have a place to host it.
Basically though, manifold reference goes into the IN on the boost control solenoid. A single line will exit the OUT on the boost control solenoid...this line will go into a T and each side of the T will go to one of actuators.
I would think that if the solenoid has it's own reference, it should be OK . . .
- Dug
Remember that you want the line from the manifold reference to the controller to be as short as possible.
- Dug
