Radiator Cap Question
Old Sep 19, 2007 | 11:07 AM
taillights's Avatar
Default Radiator Cap Question
Took car to dyno and noticed that under higher boost levels like 16lbs that the cap is leaking. Catch can was empty WHAT COULD THIS BE A SIGN OF? Did'nt notice anything around any of the heads and car is running great. Thanks for any input. Car made 77x rwhp at 16.4lbs going to stop there until I figure out the cap problem.
Old Sep 19, 2007 | 12:05 PM
smokinHawk's Avatar
cap could be defective?
could be getting some excess crank case pressure, pushing liquids, gaskets are holding but the cap isnt
first thing i would do is get a new cap.
how bad is the leak?
Old Sep 19, 2007 | 12:06 PM
MIGHTYMOUSE's Avatar
maybe your overflow tube is stopped up
Old Sep 19, 2007 | 04:06 PM
taillights's Avatar
Mighty Mouse I checked my overflow can and tube. Maybe I'll just try a new cap and see what that does.If it ends up being to much crank pressure what are some good suggestions to relieve some pressure. Thanks Smokinhawk I would say the leak is a little to much to take to the track and be on the safe side at high boost. I ran it last week on 7lbs and went 6.56 @ 106xx with only a 1.54 60ft. theres alot left. Thanks for the input
