View Poll Results: Pick one please and explain reasoning!
224/228 .581/.588 114LSA
3
13.64%
230/238 .580/.592 115LSA
19
86.36%
Voters: 22. You may not vote on this poll
Turbo Guys come on in!
Old Sep 19, 2007 | 02:17 PM
Websy21's Avatar
Default Turbo Guys come on in!
Pick a cam, its for a 408, GTS80 front mount.
8.5 CR, ported 6.0 heads, LS6 manifold, and its 95%+ street car
I already have either to install, obviously not trying to get the 'BEST' b/c I know that would be to get a custom grind. I have already spent enough money
This exact combo was ran with the smaller of the 2 and worked great but my thoughts were that its too small for the motor and the larger one would better suit the combo?????? Than again, many use something like the LS6 cam for turbo's. Help please
Old Sep 19, 2007 | 03:31 PM
HUNTER02SS's Avatar
Me personally think the duration is still a little small for the turbo size and ci.
I have only a 377ci with a 240 duration. Keep in mind the longer the duration the more air flow come's in and exhaust flow exit's,which will help in the spooling,I think? Work's good for me though. I am sure other guy's with more cam experience will chime in.
I just read you already have the cam's so I would go with the bigger one of the 2.
Old Sep 19, 2007 | 06:18 PM
otherwhitemeat's Avatar
I'm with this guy...in fact my duration is even bigger then his and my lobe sep. is 112
Old Sep 19, 2007 | 07:12 PM
Websy21's Avatar
Interesting but I was always under the impression that you wanted to have a wider LSA in boosted applications and not always bigger is better in terms of duration.
I have a buddy that has a 232/242 .580/.590 113LSA, 111 centerline. Would this perform alot better than the others for my setup? I don't doubt your cars, I mean in referal to N/A the bigger cam in most cases is better especially with bigger cubes.
Turbo's among the most seem to be the hardest to choose a cam for. I was originally going to use the smallest one and decided to switch to the bigger. Now what about the above mentioned one?
Old Sep 19, 2007 | 09:40 PM
theblur98ss's Avatar
agreed with the above. Mine is 242/238
Old Sep 20, 2007 | 05:50 AM
HUNTER02SS's Avatar
My lobe seperation is a 114, but the actual cam pattern is a single pattern and not a split. The difference in my cam is in the lobe degree's. My cam was actually spec'ed out for me to go with a big supercharger.but at the last minute I decided to go turbo's,but it seem's to work well.Just keep in mind that the above mentioned one,you will get more airflow out then you will in.What head's are you using by the way?
Old Sep 20, 2007 | 10:37 AM
Websy21's Avatar
As listed originally I am going be be running lighly ported 6.0 heads
Old Sep 20, 2007 | 02:16 PM
Websy21's Avatar
I found a link that further supports the bigger of the 2 cams. Similar project to mine other than its a rear mount. Video inside, he's running the EPP blower cam with similar specs. 232/240 59x/60x 115 LSA
https://ls1tech.com/forums/showthrea...ight=turbo+cam
Old Sep 20, 2007 | 09:49 PM
HUNTER02SS's Avatar
That cam from EPP is larger than any of the 3 you have listed and has a wider lobe sep. If it was me I would call EPP and let Bob spec you out a cam for your set up. There are hundred's of different cam's that will work well for your application. If you are wanting to know which one to go with of the 2 you listed to vote on, I would go with the bigger of the 2 since there isn't that much difference in them from the info you have given on them.
Old Sep 21, 2007 | 05:27 PM
Websy21's Avatar
Ya, I already told my builder to go ahead and put the bigger of the 2 in there
Old Sep 24, 2007 | 07:23 AM
Darren P's Avatar
bigger is better
and you are not talking about talking about going that much bigger
Old Sep 24, 2007 | 09:06 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I voted for a bigger cam, why build a large displacement engine unless you are going to take advantage of the bigger engines ability to make more power.
Old Sep 24, 2007 | 09:20 AM
Full Throttle's Avatar
238/242 .585/.592 116
