How meth affects current tune? And how to fix boost spike?
Will turning on the controller to inject a small dose simply cool the charge or will it significantly change my AFR? I figure it would only run slightly richer if anything. Boost is staying the same, im mainly looking for cooler IATs.
Also, im still seeing boost spike after installing my boost controller. Its a manual version turned all the way counter-clockwise (not adding any boost). Car is setup with .4 bar spring but quickly spikes to around 8psi WOT and then drops back. It actually used to read 6psi for full boost but after settling (after spike) it drops to 5psi and stays. It feels like boost is bleeding off but it could just be that the car has more midrange than upper. Feels like if it were a leak that it would drop below 5psi after the spike rather than stay steady.
thanks for any insight.
edited the long winded post down some. Mainly just concerned about the boost spike:
-checked and the meth controller is working. I bumped up the controller curve and ran the car. Boost came very smoothly and as it rose to full boost, the car felt tremendously stronger, as though it suddenly had a small nitrous shot on top of the boost. Ive yet to feel the car pull that car. No hesitation.
-I couldn't get the laptop to read correctly so i turned the meth back off and moved on to addressing the boost leak. My new silicone came in and its nearly 3mm thicker
so now my clamps fully tighten.Did 3rd gear run, it holds full boost (6psi) all the way through 4th gear. So no leaks. It also doesn't feel like power is falling off anymore.
NOW, heres my problem. In 1st and 2nd gear the car still spikes boost. With the tweak to the boost controller it strangely spikes to 9psi for a split second then drops to 8 and temporarily holds it then drops to 6 rather than the quick spike and drop it did before. But in 3rd/4th gear it mainly holds at 6psi.
what can I do to address this boost spike? Why mainly 1st/2nd gear?
It seems like boost spike isnt very common here
