Snow Performance Boost Cooler ?
Old Sep 24, 2007 | 07:53 AM
Zeke34's Avatar
Question Snow Performance Boost Cooler ?
I've tried the seach function but found nothing; I have the Snow Performance Boost Cooler Stage 2 with the digital variable controller and plan on having it installed at the same time as my Procharger. What I'd like to know is for those of you who are running this kit or one similiar what size resevoir are you using and where do you have it mounted? The only answer I've found so far is mounting the battery in the rear and using the oem batter location for the resevoir. Any help will be gratefully appreciated, thanks in advance guys...
Old Sep 24, 2007 | 11:33 AM
Websy21's Avatar
I haven't installed mine yet but its the small resevoir and I think you can tuck it up underneath the bumper and still be able to fill it. I haven't looked into it yet though. I plan to move my battery to the back and hopefully be able to fit my A2W resevoir in its place.
Old Sep 24, 2007 | 11:55 AM
speedracer5532's Avatar
I use the factory windshield resevoir.
Old Sep 24, 2007 | 12:50 PM
MIGHTYMOUSE's Avatar
what he said.
i have seen the tank included in the kit mounted nicely near the fuse boxes or ahead of the stock washer tank off to one side or the other.. but it doesnt hold a heck of a lot.
Old Sep 24, 2007 | 01:13 PM
great421's Avatar
Mine is a 2 Gallon fuel storage / transfer (i.e. - "red plastic") tank mounted in the trunk next to the Meth pump.
Old Sep 24, 2007 | 02:17 PM
Zeke34's Avatar
Websy I didn't even think the 2 qt resevoir that comes with the kit would fit behind the front bumper, I'll have to check that out. Also Mightymouse is that your car on Snow Performance's site? If it is, at the time that the picture was taken were you still using the windshield washer resevoir to hold the meth? Also, I just went outside to take a look how the resevoir might fit near the fuse box or on either side of the windshield washer resevoir, those are both some very tight fitting areas, how did they do it?
Old Sep 24, 2007 | 02:33 PM
Zeke34's Avatar
For this are you using 150 psi pump or the 220 psi pump?
Old Sep 24, 2007 | 05:05 PM
Zeke34's Avatar
Any more ideas for where to mount the resevoir?
Old Sep 24, 2007 | 06:44 PM
Slowhawk's Avatar
LS1Tech Sponsor
5 gallon tank in the rear pass side wheel well. We do it for road racers.
Old Sep 24, 2007 | 07:04 PM
Zeke34's Avatar
Do you guys use a 150 psi pump or the 220 psi pump?
Old Sep 24, 2007 | 09:17 PM
Zeke34's Avatar
Slowhawk could you please post pics or pic me pics of how you guys make this work with the 5 gallon tank in the rear?
