should I go STS or Procharger?
Old Sep 29, 2007 | 06:43 PM
00TurboTA's Avatar
I have an STS kit and yes it has good power but this winter i am gonna procharger my car, prochrger all the way...
Old Sep 29, 2007 | 07:10 PM
Dragframe's Avatar
I see too many sts kits just become the temp setup until they can afford a front mount... And lets not start a pissing match about the sts kit. Facts are known that it just is nothing compared to the front mount. KBracing96 on here ran a 14.7 with a sts on his 4.8 GMC ECSB 4x4 and with a front mount and same tune ran a 13.2. This was at a DA of 8000+ feet.
So i suggest the procharger. For simplisty, and cost.
Old Sep 30, 2007 | 06:28 AM
EPP's Avatar
EPP
New or used, an ATI ProCharger is a great way to go. If going used, look for an ATI ProCharger D-1SC 1GJ204-SCI kit, which is an eight rib kit with the larger 4.5" intercoolers. It may cost you a little more initally, but it will be cheaper in the long run than upgrading a six rib kit to the eight rib kit, plus the intercoolers are one inch thicker. The eight rib kit requires the use af an aftermarket harmonic balancer made by ATI Performance Products. Bob
Old Sep 30, 2007 | 09:57 AM
Boosted 99 TA's Avatar
Belts are for pants go wtih the turbo set up.
Old Sep 30, 2007 | 10:04 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
lol thats very funny.
So I guess you don't have an alternator or A/C. And you must also have an electric water pump and manual stearing. Hmmmm if so, sounds like a race car to me, not a street car.
Old Sep 30, 2007 | 10:12 AM
jeremy02's Avatar
Procharger means worse gas mileage, that's bad for a daily driver.
I got my STS kit and I was skeptical at first, and it still isn't installed, but the quaility of all the parts amazes me.
I'm sure you'll be happy with either.
Old Sep 30, 2007 | 10:21 AM
ChevyChad's Avatar
Originally Posted by jeremy02
Procharger means worse gas mileage...
Not necessarily true at all! I actually got better gas mileage on my old Z28 when I put a p1SC on it- under normal driving conditions that is. Of coarse if you are getting on it all the time and stay in the boost a lot, you will use more gas, but same is true for a turbo.
Old Sep 30, 2007 | 10:25 AM
B18CYA's Avatar
I would have to say procharger over sts kit.. more potential and very simple.
Old Sep 30, 2007 | 10:28 AM
geeteego's Avatar
Procharger guys (and vendors) are going to be biased towards, you guessed it...the Procharger. What a surprise.
Same for those of us running STS.
Get what you want. What all the rest of us want is irrelevant in your application. Do unbiased research and make a choice that's your own. You'll be happier in the long run.
Old Sep 30, 2007 | 12:37 PM
candlelit's Avatar
Thanks Bob that's great info to know
Old Sep 30, 2007 | 08:07 PM
jeremy02's Avatar
Uhh...I'm no expert or anything, but I'm definitely gunna call bullshit on that one...you added something to your car that makes your engine have to work harder to turn a pulley...more work for the engine means worse gas mileage, right?
The same can't be said for a turbo as it uses resources(exhaust gases)that are already there. STS even claims a 1-3 MPG increase with their kits.
Someone correct me if I'm wrong.
Old Sep 30, 2007 | 08:24 PM
  #32
ChevyChad's Avatar
I don't care what you believe, the fact is I got consistently better gas mileage when I was not driving the crap out of it. I could get 300 miles from a full tank with it on, and never did that good before or after I took it off. I think the reason is that I didn't have to try as hard to get up to speed. Faster acceleration means less time you are pushing it to get into cruise. This has not been the case with my T/A, I have got less MPG with it, but I am also making way more power than I did with my LT1 Z28.
Old Sep 30, 2007 | 08:49 PM
  #33
jeremy02's Avatar
I think maybe you just got on it more when you didn't have the procharger...you don't have a special car that gets better MPG with more mods.
Old Sep 30, 2007 | 09:13 PM
  #34
venom346's Avatar
Or maybe, since he had to re- tune with the procharger, the tune was better for drivablility and gas milage than the factory tune.
Old Sep 30, 2007 | 10:35 PM
  #35
LV Vette's Avatar
You already have a forged motor so either way you should be as reliable as FI can be. I have driven many turbo and supercharged cars and both can make more power then you could possible want. The biggest difference between the two are as follows:
Turbos: power comes on with increased exhaust flow which means the power comes on at various speeds and quite fast. On the street power can come on at low rpms and blow away your tires. Turbos also tend to make a little more torque then superchargers.
Superchargers: power comes on very linear because it is rpm dependent which makes it much easier to control. It is a smooth progression of power and the big power is in the higher rpm range. Superchargers will do better at the track do to more controllable power and power in the upper rpm band where you will be racing.
I am biased towards superchargers because I have one, but trust me, they easier to drive and are more reliable.
Clayton from Las Vegas
Old Sep 30, 2007 | 11:33 PM
  #36
SilverSS's Avatar
I used to have the STS kit. Now I'm Procharged. Couldn't be any happier!
Old Oct 1, 2007 | 12:21 AM
  #37
Dragframe's Avatar
hmmm.. thats odd... ever GM vehicle i have ever has (i think about 6 now) has always ran 300 miles to the tank... every last one of them (including my 96 t/a). It was like they changed the size of the tank according to the motor fuel consumption.. haha.
Old Oct 1, 2007 | 12:45 AM
  #38
TripleWhite96's Avatar
booo I only get 200 to the tank..but i've had a misfire for alittle now hah
Old Oct 1, 2007 | 01:03 AM
  #39
Dragframe's Avatar
i drive my stuff super nice though =/
Old Oct 1, 2007 | 06:02 AM
  #40
unit213's Avatar
Administrator
Get a D1 Procharger. Don't waste your time on a STS kit.
