T76 Turbo dyno results in...HELP! Need a diagnosis...
It's hard to put the full picture in text...the falloff was ocurring when metering the boost from the dash-mounted pod.
When the boost was metered at the turbo, there was no dropoff at all.
The old setup on another identical car I would not have believed if I hadn't seen it myself.
I use a leak down gauge and plumbing lug. Some pvc, and some couplers and you can adapt to almost any turbo, then plug the exhuast. I always find leaks even on "good" cars. Your exhuast housing sounds like a .81 (not 91), which is fine. I run a .68 on a 72 and previously did on a p trim 76, on a 346 stock engine, it works fine. It run 10 -14 psi on 91 octane.
look for a leak, raise the boost, make sure the bov does not open under boost, start at about 11 degrees timing then tune from their (wot)
LS1Tech Co-Founder
The riddle is becoming clearer...so in essence I have a big, noisy exhaust restriction until I put a 8# spring in and see some boost to the intake.
1320, I bought this kit used from another guy with an 04. I'm an idiot when it comes to turbos, so I have to go by what I get from the tuner, LSxGTO and here. The guy that had the turbo before me says it is a .91 backhousing. The A/R # on the fan housing says .70.
I'm certain the stock 346 with that cam moves enough air to justify the 76, as discussed. I do believe now that there is significant loss between the a$$ end of the car and the intake (The downside of remote-mounted turbos...but I have seen them make GOBS of USABLE power).
I will try the system pressure test. It seems like a fail-safe way to know where the leaks are (everything I have read tells me there are leaks somewhere...TB, etc)
PSJ, I can't think of a more simple way. Beats hell out of pulling the timing cover and taking the whole mess apart.
I'll fill y'all in when I get it sorted out. Thanks so much for the sage advice and suggestions.
Your wasegate is probly opening up causing exhaust to bypass the turbo. Just curious why would you waste your time with running 4 pounds of boost when you Have all the stuff to run at least a min of 6-8 it just sounds like a waste of precous dyno time. But I would check all the basics, compression test, Test fuel pressure, spray for unmetered air with break clean NOT carb clean rubber gaskets don't always like it. If worst comes to worse degree the cam or at least check the marks. I have seen several mechanics **** up It is very easy to do when your in a hurry.
Another thing to check that I have come across with the STS GTO kits is the snorkel intake (to prevent being exposed to rain water), it is absolutley horrible and will KILL your power , put a filter on the turbo and make a pull on the dyno and you will be amazed at the results .
Mike
Mike
Zombie, it's connected to a "log" that has multiple connections off the brake booster, manifold, etc...
antivenom, wastegate is functioning normally. Tied a string to it to see if exhaust was coming out under boost...nothing until 4psi. the reason for doing it with 4psi was that I was uncertain what spring was in the WG. The previous owner ran a MBC. Beyond that, I wanted to make sure everything was functioning correctly before I threw 10psi at it.
New Era, no snorkel on the car. Just a big 'ol K&N.
open up that WG and check the spring.
http://tialsport.com/prod_wg_38.htm
Click their PDF to see the different pressures. You should put the correct spring in there to begin with if its not already in.
IM reading this with great interest. I just went from the 60-1 turbo to a t-76 turbo and intercooler and went from 492hp to 390hp on my 04 GTO. The car just died at 5k with the 60-1 and now with the .96 ar T76 it dies at 5200. I did 6lbs spring and the 10 lbs spring and still couldn't get it over 400hp. I feel the pain!!!
Mike P
Mike P
#32
I don't want to turn the boost up until I find out why a large turbo (even at 4psi) and a camshaft gave me 22rwhp.
It saw 4psi of boost @ the turbo, but up front (dash gauge) spiked to 4psi and dropped off pretty quickly (I am assuming opening of the wastegate).
All parts professionally installed.
#35
Mike P
Mike P
#36
Originally Posted by Zombie
Do you have good valve springs? Sounds like symptoms of valve float, but it's tough to tell without a dyno graph.
Mike P
#37
All,
Getting it re-tuned tomorrow with a .8 bar spring. We're going Methanol @ 4psi-up.
There is also a conflict between the old Diablosport program that was in the car and the HP tuners program now in it. Set off a couple VATS codes and for a while the car wouldn't start after the build. So we'll strip it down to the base GM program and rebuild from there after the Diablosport program is pulled.
I think between that and the new spring, things will go just fine. I have new springs and pushrods so my valvetrain should be solid.
Boostjunkie, my air filter is pretty big already...I'll lose ground clearance if I go bigger.
