Has anyone done a setup like this? (pic)
Old Oct 1, 2007 | 12:08 PM
Reject's Avatar
Default Has anyone done a setup like this? (pic)
I'm brainstorming on how i want to go about on my turbo setup, and am trying to see which way would possibly be the easiest in terms of not having to relocate accessories or even delete them. I've drawn up a quick little sketch on how i was thinking but i will need to explain it to give yall a better idea.
The passenger side header is going to be a super shorty with a crossover pipe going flat (like stock Y-pipes) under the tranny/engine section to merge to a log like driverside header. Going to try and keep the pipes as close to the block and up high enough becuase i'm wanting to run the downpipe back that direction under the log (still with the stock K-member) Just wanting to ket an idea on how this would look/work/fit and if anyone has done it like this before. I think it resembles the TTi kit maybe? i'd run this on the stock 346 everything minus a 226 cam until it blows up on a T70 to be able to upgrade without having to buy a new turbo again.
Anyways i included my CAD drawing of how i invision this. ALL input is welcome. Thanks!!
Old Oct 1, 2007 | 12:16 PM
PLucas's Avatar
You would still have to relocate the alternator
Old Oct 1, 2007 | 12:19 PM
Reject's Avatar
do you think i could make the pipe move outward to clear itand then bring it back around past the alt ?
Old Oct 1, 2007 | 01:23 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
This pic from my build might be helpful:
Old Oct 1, 2007 | 01:35 PM
PHIL H's Avatar
Is that an HKS wastegate PSJ?
Old Oct 1, 2007 | 01:36 PM
Reject's Avatar
Have any more pictures? did you just flip the stock manifolds forward and Y them up front? seeing from that view it looks like it but i'm not completely positive. Thanks for the pic
Old Oct 1, 2007 | 01:56 PM
Josh@MASPORT's Avatar
Closed Sponsor Account
thats the TTi kit
Old Oct 1, 2007 | 02:13 PM
Reject's Avatar
the one that PSJ is using or the one that i drew up?
Old Oct 1, 2007 | 02:29 PM
LS1Tech Co-Founder
Flipped manifolds...
All pics here:
http://psj.ls1tech.com/gallery/main.php
Old Oct 1, 2007 | 02:30 PM
LS1Tech Co-Founder
Hks Ii Wg.
Old Oct 1, 2007 | 02:43 PM
MIGHTYMOUSE's Avatar
tti street kit side view
Old Oct 1, 2007 | 02:48 PM
Reject's Avatar
nice nice! thank you VERY much!!
i guess that setup has been done then!! guess it will be better to just buy it already made than fabb up my own?
