To Memphis or not to Memphis... Head Gaskets **PICS**
Old Oct 7, 2007 | 11:16 PM
Blownramair's Avatar
Originally Posted by kp
Dont remember, that was over a year ago. If I remember #4 was the worst cylinder so I would say RH side.
I've had problems with the left side - back two cylinders...
Dyno Tune is Tuesday/ Wednesday and hopefully NOTHING breaks on it... The guy up here is pretty damn near perfect on tunes... I hope i can give it enough fuel as it wants bc i believe the 65lbs injectors are almost MAXED...
If i can run some low 9.6x's i should be okay... I'll just tree the **** outta the other dude right?
J
Old Oct 7, 2007 | 11:39 PM
kp's Avatar
kp
J
Weather will be good, Memphis is fairly quick, I'm sure you can run .50s with no problem. Most guys running arent professional bracket racers so you never know. Just remember its a .500 pro tree so if you are cutting better than .100 lights on a .400 be careful
Old Oct 8, 2007 | 05:11 AM
EPP's Avatar
EPP
Good luck, hope to meet you in Memphis. Bob
Old Oct 8, 2007 | 05:20 AM
Same here bob! Gonna have a rough few days putting this entire thing back together... I have no room for any errors...
J
Old Oct 8, 2007 | 05:29 AM
Inspector12's Avatar
TT-TECH Veteran
Originally Posted by INTMD8
Is that what ended up being wrong with your turbo car?
No that was with the original Vortech setup like SSilversurfer said. I bent the valves on atleast 5 of the cylinders so I will be calling you when I get it back out again.
Old Oct 8, 2007 | 03:33 PM
onfire's Avatar
Coal Mining Director
J
You're making too much power for 65 injectors.....you can max them out with a GREAT fuel pump(s) and get by, but you need at least 86's.....good problem to have though....nice car.
Old Oct 8, 2007 | 04:22 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Blownramair, what is your base fuel pressure? I'm guessing it must be pretty high to still be running those injectors.
PTE is shipping my turbo back right now, we should have it tomorrow afternoon since they are just over in IN. Matt in repairs said that the contact the impeller was making with the housing could be the reason why the car would not boost up. As long as the car works tomorrow night i am bringing it.
Old Oct 8, 2007 | 08:04 PM
Fuel psi is at 60psi and i believe the injectors are at 85% duty cycle... I know i need bigger injectors... I'm waiting till over the winter bc i'm doing a E85 kit and prolly goin with 160s w/ a bigger combo...
I do have a pretty good fuel pump (FAST 1200hp kit) and im sure it'll be MAXED for Memphis... Or ill just have it tuned to as most she'll go... Id rather not have the motor set on kill at this time...
How HIGH CAN I TAKE MY FUEL PSI??????
Old Oct 8, 2007 | 10:51 PM
blackz93's Avatar
I'm waiting for my turbo to come back, I was having problems getting the car to boost up and one thing we found was that the impeller had made contact with the housing... that's racing. .
Where did you get yours from?
Old Oct 8, 2007 | 11:15 PM
Caveman's Avatar
10 & 11 Second Club
J
Just get it done, there is a number of guys getting ready at the last minute including me. If your running the 9.5 index good luck at cuting a light on KP.
Old Oct 8, 2007 | 11:19 PM
kp's Avatar
kp
I claim to be a lot of things but a good driver aint one of them lol. You going to make it to the shootout Dave?
J, you can bump up the fuel pressure as much as you can until it cant hold it at high duty cycle. 85% isnt bad, heck I'm running my 75s at 95% or so.
Old Oct 9, 2007 | 07:39 AM
  #32
MIGHTYMOUSE's Avatar
the engine looks so new, i figure there are hardly any miles on it.. i wonder if it ever even got water into the heads in the first place?
i agree not gaskets, but i also didnt hear what brand was on it.
was your radiator low? was it all in the overflow?
Old Oct 9, 2007 | 08:34 AM
  #33
LS1Tech Co-Founder
Hijack, but mine is a GT47-88 from PTE, good guys, they will be at the shootout.
Old Oct 10, 2007 | 11:38 AM
  #34
Boy did i find a lot of things wrong today about the car while on the chassis dyno...
We uped the fuel psi to 70 and cranked the injectors to 97%... Still wanted to run lean but we got her on the safe side... The leanest it went was 12.2 and thats around 6400rpms... I cant change anything in Memphis bc i dont have an aftermarket engine management system...
She'll run "just a lil" faster than 9.50
And for cuttin good lights, I shouldn't have a problem in that area unless my tbrake button takes a ****... Kp's just gonna have to slow his car WAAAAAAY DOWN to KEEP UP with me, LoL...
Either way some engery drinks and a 13hr ride...
See y'all Friday...
Old Oct 10, 2007 | 11:43 AM
  #35
onfire's Avatar
12.2 on a dynojet will jump into the high 12's at the track....if it's cool at Memphis it could go leaner....good luck!
Old Oct 10, 2007 | 12:12 PM
  #36
LS1Tech Co-Founder
I'd fatten it up, sounds kinda lean.
Still no turbo on my end.
Old Oct 10, 2007 | 02:13 PM
  #37
cablebandit's Avatar
i'd fatten it up and use whatever fuel makes it run richest.....so far that has been c16 for me but i have very limited experience with different race fuels....maybe KP can chime in on fuels to use. That lean and you need all the insurance you can get!!
Old Oct 10, 2007 | 05:17 PM
  #38
It only hit 12.2 for 300rpms around 6400. Then it flat lines at 11.5 every where else... 12.2 was the MAX LEAN it went on a mustang dyno... The temp in Michigan was 49* when it was on the dyno - i highly doubt it'll be that cold in Memphis... I can take the fuel psi up 2-3psi w/o the computer going outta wack to fatten it up a bit... That's about all i can do w/ the stock pcm.
After a blast or two in Tn, I'll pull the plugs and see what they look like... Any signs of goin lean, I'll up the fuel psi 3psi or so...
PSJ, you still comin regardless???
J
Old Oct 10, 2007 | 05:20 PM
  #39
ahhh mustang dyno...all the difference in the world
Old Oct 10, 2007 | 05:23 PM
  #40
Kp uses c16 and i run ms109... I purchased a drum last year and so far the 109 is getting me by... Kp's prolly makin around 80-100hp more than me with his 3.4/ 7.25 combo on the d1 than i am... I still have lil baby newborn heads
The tuner here said i will be okay for Memphis... He's very well trusted in the Detroit area... I'm thinkin a new best might be around the corner - well 13 hrs away, but still
