Will a torn wastegate diaphragm cause low boost?
Old 10-12-2007, 08:04 AM
SPRAYED 01's Avatar
Its a speed density tune so there is no maf.
Old 10-12-2007, 08:17 PM
ddnspider's Avatar
Received 1,746 Likes on 1,304 Posts
does it have the stock map sensor?
Old 10-13-2007, 01:02 PM
SPRAYED 01's Avatar
No i put the 2bar sensor in that i bought at the dealer. Part number is 12580698.
Old 10-13-2007, 10:42 PM
ddnspider's Avatar
are your O2 sensors in good shape?have u visually inspected the turbo,ie the wheels?
Old 10-14-2007, 10:05 AM
SPRAYED 01's Avatar
The 02s have about 3k on them and seem to work fine. i have inspected the wheel on the inlet but i have not actually taken the turbo apart.
Old 10-15-2007, 07:46 PM
SPRAYED 01's Avatar
Here is a little update on the issues. I rebuilt the wastegate and ruled that out after hours of testing. I found that i had a rip in the bov diaphragm so i fixed that up and now that works great. From a dig i go full throttle,it gets to 10psi and feels great instantly, then as soon as it hits 10 it goes back down to 0psi instantly. So i had a friend in the car watching the boost gauge while i watched the af gauge. I stayed full throttle after it droped to 0psi. Not only does it drop to 0 but it starts to pull vacum. It will never go back up to boost untill i let off the throttle and get back into it.
Old 10-15-2007, 09:38 PM
LS1Tech Sponsor
Brady's Avatar
sell it?
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
Old 10-08-2008, 05:15 PM
How do I change this text
Wilde Racing's Avatar
THEAD FROM THE DEAD!
Did you ever figure this problem out? I'm having wastegate issues of my own....
Old 10-08-2008, 08:14 PM
SPRAYED 01's Avatar
Wow its been a while and ive learned so much since then. It actually was something really stupid. The air intake tube on the inlet of the turbo had a 90 degree elbow that was collapsing shut. I removed it for testing purposes and it worked fine.
Now im running a really heavy duty rubber 4inch elbow.
Old 10-08-2008, 08:17 PM
LS1Tech Sponsor
Brady's Avatar
Originally Posted by Brady
Is it a possibility that the inlet plumbing to the turbo (from filter) is collapsing?
who'd a thunk it?
__________________
2016 Z07 Carbon
Old 10-08-2008, 08:35 PM
bboyferal's Avatar
who'd a thunk it?
lol,
Still weird that it would go lean and not rich though...
Quick Reply: Will a torn wastegate diaphragm cause low boost?
