PTK/S kit users, question.
Old Oct 28, 2007 | 10:37 AM
bboyferal's Avatar
My motor mounts have been fine for 10k miles.
I would cook a little PS fluid... Not overflowing but some would evaporate and moisten up the PS reservoir around the cap... Wrapped the PS lines nearest to the exhaust housing and it's helped alot.
For oiling, mine is gravity fed and getting a healthy dose of oil. To prevent some smoke, I'm running an electric scavenger pump to pull... To keep good oil pressure, I'm also running an oil cooler positioned parallel to the street in my air dam that gets air on its way to the radiator in the stock position... Always have good oil pressure and good temps.
Old Oct 28, 2007 | 11:18 AM
Reject's Avatar
I will end up ordering one of smokingHawk's brackets some time this week, did yall see his version 2.0 bracket? looks great!
Old Oct 28, 2007 | 12:30 PM
trever phillips's Avatar
Originally Posted by Frost
I have a modified PTK bracket, I have to have my factory alternator rebuilt (using the PTK one still) before I can try out my Smokinhawk bracket.
As far as the mount.... I had this "mystery smoking" coming from the driver's side for the longest time, and I couldn't figure out what it was. It was the rubber in the mount. Seems like Countryboy may have had the same happen to him.
Frost your car is sick I bought his kit he wrapped everything and i wrapped the steering shaft also Do you remember what turbo he had I lost the box he said he thouht it was the 76gts also
Old Oct 28, 2007 | 01:11 PM
Frost's Avatar
I think he had that tc76mps .... or something like that It's one of those specialties from Forced Inductions. From what I remember, it didn't peak quite as high as a gts but it spools a bit quicker.
Old Oct 28, 2007 | 01:17 PM
Frost's Avatar
This pic shows the mount. The downpipe is on the topside and the crossover from the passenger side is removed in the pic but runs right below. I had my pipes out, so the wrap isn't on in the pic, but they were wrapped... You can see the oil feed in the pic too.
Old Oct 28, 2007 | 08:41 PM
Reject's Avatar
do you have a pic of the front of the oil feed line? like where it starts at?
Old Oct 28, 2007 | 10:05 PM
Frost's Avatar
the kit came with a boss and a fitting that bolt up right at the filter to feed the turbo, but sorry, no pic of that.
Old Oct 28, 2007 | 10:06 PM
Frost's Avatar
Actually, if you look closely in this pic you can see the fitting to the pan on the return line below the crank pulley:
Old Oct 28, 2007 | 10:22 PM
Websy21's Avatar
Thanks for all the help frost, I love that vid in your sig. It pulls pretty damn hard, I can't wait to get my kit on my 408. Can't remember what you made for numbers but was pretty stout, you accomplished a very nice, clean build
Old Oct 28, 2007 | 10:53 PM
Frost's Avatar
I couldn't make boost on our local dynojet very well; only saw like 10.2psi... and that was back on a MAF tune, so it was fueling for about 11.0:1 at 17-18psi and pegged my wideband fat with only 10psi. Still made 590rwhp and 575rwtq suprisingly. Tonight while I was out on an errand it was running nice in the 59degF air. Even after getting the tires hot a few times in second it still wouldn't hold second gear at all. I was seeing 16.5psi in 3rd gear so I will prolly back the eBoost down a tad. I absolutley love the car and driving it. I couldn't have done it without the help of the guys in RPM and of course LS1tech. CAM also did the swap for me down at their shop in Durham. Jeff Creech helped out a lot after my first engine went south. I can say though, that now after a career change I am no longer travelling and my car will never sit at another shop. ....Well, excluding a chas. shop
Old Oct 28, 2007 | 10:56 PM
Reject's Avatar
yeah that's pretty close from the top view but when you look at it from the front it's really not that close, would you guess that line is like 2 feet long?
Old Oct 29, 2007 | 02:28 AM
  #32
Frost's Avatar
yeah between 12-16" I'd say
