Blowing off and still surging - BOV too small?
Old Oct 24, 2007 | 02:49 AM
thunder550's Avatar
High on diesel fumes
Default Blowing off and still surging - BOV too small?
The new BOV that I installed seems to be very responsive, but even when it blows off the turbo still surges. Does that mean it's not big enough? Would running two BOV's solve the problem?
Old Oct 24, 2007 | 08:59 AM
Turbo LS1 SS's Avatar
what BOV turbo and engine?
Old Oct 24, 2007 | 11:23 AM
thunder550's Avatar
Synapse BOV, PT76GTS, 408ci engine
I spoke with the place that I bought the BOV from and they want me to try removing one of the springs. I'll report back after I try that.
Old Oct 24, 2007 | 03:00 PM
thunder550's Avatar
Tried removing the spring, seems a little better. Took a few videos. Tell me if you think this sounds normal or if there's still too much surge.
Video 1
Video 2
Video 3
Old Oct 24, 2007 | 03:45 PM
67Firebird455's Avatar
I've heard worse, but you're right, it is surging quite a it. How many mm is that blow off valve?
Old Oct 24, 2007 | 04:46 PM
thunder550's Avatar
It's something like 30-35mm. The shop told me that because it opens faster than a standard BOV it makes up for the size difference, but I dunno if that's true. I'm wondering if it's just too small. I swapped to this from a TiAL 50mm to eliminate part throttle surge. The TiAL worked great at high RPM and high boost but not very well at part throttle low RPM. This Synapse BOV seems to be the opposite.
The second video I posted above actually sounds about like I would expect a good working BOV to. The others two are not so much.
Old Oct 24, 2007 | 05:01 PM
thunder550's Avatar
Just spoke with Synapse and they are going to send me a replacement, they think something might be wrong with the one I got. I'll update again once I receive it.
Old Oct 24, 2007 | 09:34 PM
Bill Reid's Avatar
Keep me posted bro... I want to get the Synapse... I may tie one in on top of my Tial if you still have surging after the replacement. I have the EXACT surging signature that you do!
Bill
Old Oct 26, 2007 | 09:01 AM
nandofabricado's Avatar
well what spring did you have in the tial theres a 7 and 9 and i think 11 psi springs for the bov
i would just run 2 50mm tial with the 7lb springs
Old Oct 26, 2007 | 09:40 AM
thunder550's Avatar
I had the 9psi spring in the TiAL. Going back is not an option, I already sold it. If one Synapse doesn't cut it, I'll just add a second one.
Bill, I'll let you know what happens It actuates VERY quickly under part throttle low boost. All of my low boost surging is gone completely. I'm hoping the one I got is defective, because I love how fast this one releases.
Old Apr 30, 2008 | 09:20 PM
blacksi's Avatar
Damn, no update?
