Dynoed with the F1 today... few problems...
I just found out some interesting info from reviewing the videos from the dyno. It appears that the fuel pressure DOES drop from 70 to 60psi in the upper RPM's. I couldn't tell by reviewing it on the small screen on my camera, but now that I loaded the vids onto my computer it is very apparent. I am loading a couple vids up on photobucket right now. I'll post them up here as soon as they finish loading...
I really don't want to raise the compression at all by getting the heads resurfaced. They only have not even 4000 miles on them, so I'm hoping they will be okay to just put back on as is without any milling...
I'm still wondering what the black smoke was out the back near the end of the runs this time. It did it on both pulls after reviewing the videos. What is even weirder is that the cutout was open, so I don't know how any exhaust got to go thru the muffler...
I then tried to put it back on and it wouldn't even stay on without falling off. So I highly doubt that could have been supporting any current going through it
I crimped the connection with some pliers and put it back on the lead. This time it was snug and actually held in place. I put it on the normally closed connection and turned the key and sure enough it primed. Now I know the second pump works, and I highly doubt it worked before. Then I put the connector back on the normally open spot and buttoned everything back up with the primary pump. Hopefully, that was my only problem and the chain of events were as follows: It went lean because the second pump didn't come on which caused it to detonate and blow the head gasket. Hopefully that is all that happened. I called up Matt @ SDPC and ordered the 5 layer MLS gaskets today. They should be here by Wednesday, and maybe I'll get a chance to put them on this weekend. I can't believe all this happened because of a freakin loose connection. But hopefully, that was the only thing wrong and I don't have to do a whole new fuel system. The Best V8 Stories One Small Block at Time
I crimped the connection with some pliers and put it back on the lead. This time it was snug and actually held in place. I put it on the normally closed connection and turned the key and sure enough it primed. Now I know the second pump works, and I highly doubt it worked before. Then I put the connector back on the normally open spot and buttoned everything back up with the primary pump. Hopefully, that was my only problem and the chain of events were as follows: It went lean because the second pump didn't come on which caused it to detonate and blow the head gasket. Hopefully that is all that happened. I called up Matt @ SDPC and ordered the 5 layer MLS gaskets today. They should be here by Wednesday, and maybe I'll get a chance to put them on this weekend. I can't believe all this happened because of a freakin loose connection. But hopefully, that was the only thing wrong and I don't have to do a whole new fuel system.That why I am running one pump. Sorry to your having problems.
I crimped the connection with some pliers and put it back on the lead. This time it was snug and actually held in place. I put it on the normally closed connection and turned the key and sure enough it primed. Now I know the second pump works, and I highly doubt it worked before. Then I put the connector back on the normally open spot and buttoned everything back up with the primary pump. Hopefully, that was my only problem and the chain of events were as follows: It went lean because the second pump didn't come on which caused it to detonate and blow the head gasket. Hopefully that is all that happened. I called up Matt @ SDPC and ordered the 5 layer MLS gaskets today. They should be here by Wednesday, and maybe I'll get a chance to put them on this weekend. I can't believe all this happened because of a freakin loose connection. But hopefully, that was the only thing wrong and I don't have to do a whole new fuel system.Sounds like you may have found your problem. Ain't that a b**ch?
I'd say you found your problem...
my only worry is, what if one dies when at WOT going down the road one day.... kaboom i guess?... that's a scary thought.... just b/c of this, i may go with a single pump this winter...
Exactly why I went with a big single. Only downfall I can think of is a little noise, but my car has 1000 watts of stereo power and a loud exhaust so its no big deal at all.
We had a 346/F1 car that would always lift the heads when we pushed timing.It would make 780rwhp all day but add 2 degree's of timing and push 840rwhp the heads would lift with no KR. We figured it was the pump gas doing it.
But that is interesting- I didn't know it could detonate and lift the heads without any KR. That is scarry... So how are you supposed to tune it not knowing where the threshold is by looking for KR?
Jeff
Now I just hope the only destruction was the head gaskets
