gears
Car has been a best of 6.49 @110 in the eighth. The car is on the limiter(6400) in 2nd(th400) when crossing the traps. Its going to get more boost and heads for next year. I would like to see high to mid 5's out of it.(trying to be reasonable here). I wont turn it any higher than 6800-6900rpms.
It will see mostly 1/8th mile stuff, going to a 1/4 track maybe 2-3 times a year. I dont really care about driving it on the highway, if it needs to go somewhere it will be on a trailer, although it does see decent street miles, gotta get to work on a nice day ya know?
I put this in here because gearing for turbo cars always seems to be different than everything else, thought this place would have the best knowledge.
i didnt make it a poll because no one reads what you typed when they can just vote and be done with it.
If you are able to launch hard enough to spin with the 2.73's then I don't think you need to go to a much higher gear since all it will really do is cause you more traction issues.
stick with 3.25's of 3.08's there is a reason i told you to trade for those gears in the ten bolt in the first place. But what do i know, i drive an import
secondly, if the engine is allready working as hard as it can to get down the track, how does going to a lower gear somehow summon more power?
you gear a car based on shiftpoints, tire size, and max mph needed in high gear. for an auto you need to figure in your slip%
heres one of many calculators for example
http://www.wallaceracing.com/calcmph.php
With 3.50 gears I could not get traction if I left with more than 1psi of boost off the trans brake. With the 2.75's I could leave with 5psi and traction. My setup has a tight converter and not leaving on boost causes slower spooling, slower spooling = less power put the the ground = slower times.
Say from 0psi it takes me 2 seconds to reach 18psi from dead stop. If I build 5psi of boost before launching it now only takes me .25 seconds to reach 18psi. But if I have the extra torque multiplication of 3.50 gears vs my 2.75 gears I can't hook the extra torque and end up spooling slower. It's a giant balancing act of traction, spooltime and torque and every setup is different.
Going from a 2.73 gear to a 3.50 gear will not improve times if you can't hook the extra torque and end up spooling slower as a result. This varies with different setups. There are a lot of variables in play, torque converter, how fast the turbo spools, how well the car can hook, etc.
I think my car can leave in the 1.4x range with some susp work and a well prepped track (something i rarely get to run on). Having less gear like I do requires me to leave on more boost to make up the difference in applied torque. I could leave the same way I do now even if I changed to 2.40 gears, I would probably have to leave on 10psi vs 5psi though. The amount of boost you leave on is affected by gearing, if you are racing competatively you probably don't have 3-4 seconds to sit on a transbrake to get 10psi so this can affect your gearing selection as well. You might choose to sacrifice better ET's for time need to to stage the car properly.
For the record, most people think i'm nuts to run 2.75 gears in my car and don't understand how i'm able to leave as hard as I do with such a "crappy gear".
It has a good bradco converter in it. It leaves way too soft right now, and i know putting a lower gear in it will help, so 2.xx is out.
i understand that avoiding spool up during a run is very important to ET, so if having too much gear makes you spin (and you can't adjust anything else) and leaving easier gets you into spool problems, that dropping gear is a good solution.
i just wanted to remind all that gear set up is math not opinion or feel or advice etc.
to get the car to the other end as quickly as possible, you want to have as much tq going to the ground as possible, which means run as tall of a gear as you can given your tire size, max rpm, and ideal trap speed mph considering converter slip if you have one.
i run a 3.42 gear with my 4l80 and due to how fast the car ended up running this year (i figured the car would drop mph with the auto swap) i am just on the wrong side of things and would do better with a 3.23. moser doesn't do that ratio so i'm looking at a 3.08 OR putting a large tire back on the car for next year.
I dropped from a 3.73 to a 3.08 to a 3.00. Even dropped 1st gear down to a 2.10....so my overall 1st gear is 6.3 : 1 ......runs 5.8 in the 1/8th ....9.2 in the 1/4 at 3700ftDA 1.37 sixty when it hooks up....rev limiter at 6500 rpm...3800lbs....with 325's I'm still fighting traction problems......boost > gear.
Coop run some numbers thru that online calc link that was posted, you can see that a 3.70 would be pushing it for mid 5's and a peak rpm of 7000. I am running 3.50's and have not even come close to maxing out my rpm potential. According to the gear calcs and assuming I go up to 7400 next time I can do 167mph.
I'd like to try a 27-28" tire to see how it work on my car with my crazy gears. I didn't want to give up my ABS yet though.
I am on my 2nd set of 325 mt dr's. I have a full suspension set up & it will waste the mt's on the street. My car is strictly a street driver & I have no regrets with this gear selection.
This is on a little 347 & tc76 turbo.
Not many manual trans people want to race from a roll either once they find out I shift the 2-3 at 110 mph.
My theory was that I could gear my car to run the 1/8 mile like a power glide and just let the performance in 3rd fall where it does. I trap 6.5-6.7 @ 105-107 in the 1/8 mile on a good pass and pickup 26-28 mph by the 1/4. Once I get the chasis good I'll probably be going 6.2-6.5. 2.75 gearing is outside of the box thinking, but it's worked pretty good so far. I'm a full weight street car and don't want a race only car. I drive it about 100 miles / week.
