Pump Gas Turbo
Old Nov 3, 2007 | 02:15 AM
chrismorales75's Avatar
Default Pump Gas Turbo
What's the most recorded hp for a LS1 turbo motor on pump gas?
Old Nov 6, 2007 | 03:48 PM
red beast's Avatar
I think a couple of guys on here have pulled over 1000....I made 879 on 93 octane with no meth, at 12 psi....I only run 7 psi on 93 now everyday just to be safe, if I turn it up I put 110 in it...
Old Nov 6, 2007 | 04:06 PM
2000 Tran Zam's Avatar
i made 893rwhp on 91 no meth... but didnt last too long, lol.
Im sure there guys over 1000rwhp on it, but its far and few between... plus people now a days such as myself learned the heardway and wont take another chance.
Old Nov 6, 2007 | 09:33 PM
nitrorocket's Avatar
I have been running over 800 rwhp for over 2 years on 93 with stock cubes. The tune is the whole key to a long life provided the motor is built right in the first place. Big cubes are where its at if you need more power then 850 rwhp reliably.
Old Nov 6, 2007 | 09:38 PM
02SSLE's Avatar
dude that is really good power.
Old Nov 6, 2007 | 09:47 PM
MoreJuice's Avatar
I made 1200rwhp on pump aval. E-85.
Old Nov 7, 2007 | 09:51 AM
very good power for sure... only negative about e85 is you need to run something like 30% more fuel to the motor if I remember correctly.
Old Nov 7, 2007 | 10:02 AM
1INSANEGTO's Avatar
Yeah E85 @ 1000-1500rwhp your looking at 160lb injectors and a badass fuel pump
Old Nov 7, 2007 | 11:38 PM
MoreJuice's Avatar
Yep, I ran out of a Magnafuel 4303 at 1200hp and at 96% on the 160lb injectors. Adding another pump and switching to the 240lb injectors.
Old Nov 7, 2007 | 11:44 PM
mahhddgtp's Avatar
Dem some big injectors... Jesus! Very gross to hear you've almost maxed 160's
Old Nov 7, 2007 | 11:45 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Is it even going to be able to idle with 240lb injectors? If the purpose is pump gas I'm guessing you plan on driving it a lot. Why not run a 16 injector setup?
