Some technical supercharger questions
I've heard of running a crankcase evac system and that you can run them to your headers or to the suck side of your supercharger but I don't quite understand how it sucks pressure from the bottom of the engine when it's being sucked from the top (valve covers)?
Also do rings take time to seat?
I ran more breather lines to catch cans when I upgraded to the T-trim and really started making over 10#. I have a -8 line to the front of my oil pan, on each valve cover I have a K&N breather and a -6 line to a catch can.
I don't like using a blower 'suck' vent with an intercooler, because IMHO it gets the inside of the IC dirty with oily residue too quickly and cuts down its efficiency.
Rings do take time to seat. What kind do you have?
Jim
Jim
I haven't gotten the car yet...tomorrow but I know the 2nd rind is gapless from my understanding.
Jeff
Jeff
Jim
My Site: http://home.mindspring.com/~jim_fisk/id1.html
Jim
On mine the dipstick tube isn't flying off or anything like that, rather under throttle it's leaking out oil from the crack of the dipstick tube and dipstick.
Mike, where would you run a set up like that on a supercharged (vortech t trim) application?
Thanks
sworaz, the stock Vortech setup should run a single vent from the PS valve cover to the plastic SC inlet pipe. You'd simply replicate that on the DS valve cover. Drill and tap another hole in the SC inlet pipe.
Mike
